Hi folks - again looking for your expertise. Thanks in advance for any help you can offer.
Gibson Falcon Crestline - GA 19 RVT (But using M-216 RVT schematic which matches closer)
Speaker is dated: September 1975
V1 - 6EU7
V2 - 6EU7
V3 - 6C4
V4 - 6EU7
V5 - 6V6
V6 - 6V6
V7 - 5Y3
Reverb Transformer
Gibson Inc
E-6400
9966510
I took these measurements with the reverb tank disconnected and the other leads disconnected from the circuit.
Primary - 0.8 Ω
Secondary - 1.424 kΩ
I am repairing and trying to bring back to life this amp for a friend of mine. I’m not entirely new to amp repair but I would consider myself at best a novice.
I have replaced all the electrolytic capacitors and installed new JJ 6V6s and a new JJ 5Y3. I have replaced the extension cable with a decent grounded power cable. The amp now will turn on and sounds normal. For the most part all the voltages seem to be approximately correct. The amp now sounds quite good actually. Except there is no tremolo and no reverb. I have been trying to trace the problems but I just don’t feel advanced enough in my study to move ahead any further. I have traced the signal through with a scope to the best of my ability.
I have signal on the grid and coming off the plate of the reverb driver.
When I give the reverb tank a shake I can hear the return at the speaker.
I would perhaps suspect that the transformer is bad but for a few moments a few months back, both the tremolo and reverb functioned for a few moments, ever so briefly and somewhat unreliably, but they sure did sound nice.
I don’t really know where to start with the tremolo circuit. It is I think a bias shifting oscillator acting on the grid of the 6V6s. But I’m relatively unsure how to trouble shoot this.
V1 - 6EU7
PIN 1 - Heater
PIN 2 - Heater
PIN 3 - NC
PIN 4 - Cathode 2 1.14 VDC
PIN 5 - Grid 2
PIN 6 - Plate 2 114.5 VDC
PIN 7 - Plate 1 176.3 VDC
PIN 8 - Grid 1
PIN 9 - Cathode 1 1.54 VDC
V2 - 6EU7
PIN 1 - Heater
PIN 2 - Heater
PIN 3 - NC
PIN 4 - Cathode 2 1.26 VDC
PIN 5 - Grid 2 0 VDC
PIN 6 - Plate 2 167.5 VDC
PIN 7 - Plate 1 123.6.3 VDC
PIN 8 - Grid 1 0 VDC
PIN 9 - Cathode 1 1.05 VDC
V3 - 6C4 - This should be/is the reverb driver
PIN 1 - Plate
PIN 2 - NC
PIN 3 - Heater
PIN 4 - Heater
PIN 5 - Plate - 220 VDC to transformer
PIN 6 - Grid
PIN 7 - Cathode - ~ 10VDC
V4 - 6EU7
PIN 1 - Heater
PIN 2 - Heater
PIN 3 - NC
PIN 4 - Cathode 2 - 39.75 VDC
PIN 5 - Grid 2 - 21.48 VDC
PIN 6 - Plate 2 - 190 VDC
PIN 7 - Plate 1 - 136.4 VDC
PIN 8 - Grid 1 - 0 VDC
PIN 9 - Cathode 11.01 VDC
V1 - 6EU7
V2 - 6EU7
V3 - 6C4
V4 - 6EU7
V5 - 6V6
V6 - 6V6
V7 - 5Y3
Reverb Transformer
Gibson Inc
E-6400
9966510
Primary - 0.8 Ω
V1 - 6EU7
PIN 1 - Heater
PIN 2 - Heater
PIN 3 - NC
PIN 5 - Grid 2
PIN 8 - Grid 1
V2 - 6EU7
PIN 1 - Heater
PIN 2 - Heater
PIN 3 - NC
PIN 1 - Plate
PIN 2 - NC
PIN 3 - Heater
PIN 4 - Heater
PIN 6 - Grid
V4 - 6EU7
PIN 1 - Heater
PIN 2 - Heater
PIN 3 - NC
