Measuring inductors
hodad
ATL
I have one of those cheap LCR/Transistor testers (like this: tester), and when checking inductance across one side of a transformer I get a different reading depending on which pair of the 3 connections on the meter I use. As a f'rinstance, I'll see 2.4 Henries if I'm hooked to 1 & 2, but 3.8 across connections 2 & 3. I'm a little befuddled as to what would cause this difference. The meter, considering its cheapness, has proven pretty useful in other situations, and I can't quite figure out why I'm seeing what I'm seeing here.
What kind of transformer are you trying to measure?
Just a crappy little 600:600 OEP. I've also tried with another small isolation transformer of unknown origin with similar results. Measuring across either primary or secondary produces similar results. I'll probable just build a couple of simple filter circuits & see which value seems best reflected by the behavior I see.
Apparently it struggles with measuring inductance across a transformer. The manual is not terribly clear on whether it has trouble with all inductors over 1H or not. It does seem to work fine with smaller value inductors though.
FWIW I vaguely recall (on another forum to do with discussing (guitar, bass, etc.) pickups that some LCR meters have trouble measuring L when the R is (relatively?--not sure exactly how much) high. I was rather disappointed with my (IIRC) A&D 5827(?) LCR meter which was kind of expensive for occasional hobbyist use (it was only after I bought it that I found many of the pickup winding people seemed to be primarily using another model (which I forget the name of) which apparently did work for measuring pickups (and was less expensive than the one I purchased, to boot).
After that a parts seller/store (here in Japan) started selling the (Taiwan made) DE-5000 (from 2012 according to the web page) and did one of those "mass purchase (10,000 units initially according to their FAQ) and pass the cost savings to the consumer" type deals (maybe USD$50-ish at the time for the unit only without the accessories (which were also very reasonably priced--credit to them), and those apparently are okay to measure pickups with--which I bought since the price seemed too good to pass up on. (Those are the ones on ebay coming from various individuals from Japan with the Japanese text on the box--unfortunately the price has gone up since they apparently pay in USD and the Yen has weakened vs. the dollar a lot--took a quick look and they are about USD$61 for the unit only, so still not very expensive, however since they don't ship internationally I guess you have to buy from some intermediary if you want one.) Anyway, perhaps there is something better now (I haven't really kept up with the latest available).
