pstamler
Hi folks:
I tried to post this when the holidays were in full swing; the server wouldn't accept it. I'm now going to follow the suggestion of eliminating all "special characters" -- in the first sentence I had included the symbol for "degrees". We'll see if it works. If so, this is a favorite recipe; merry post-holidays
Fort Chartres Gingerbread, v. 8.0 (9x9", but see below for doubling the recipe)
Preheat oven to 325 degrees F. Start boiling a kettle of water on the stove. Using "spreadable butter", grease and flour a 9x9" baking pan. In a large bowl, cream:
1/2 cup (= 1/4 lb.) "spreadable butter" (see note 2 - very important)
2 tbsp. sugar
In a small cup or bowl, combine:
1-1/2 tsp. Ener-G Egg Replacer (formerly Jolly Joan Egg Replacer -- see note 3)
2 tbsp. tap water
[OR, if you're not serving it to me, beat one egg.]
Mix into large bowl. Stir in:
1 cup light molasses (I prefer Grandma's but Brer Rabbit works fine too)
1 cup boiling water
Set aside. Sift and measure:
2-1/4 cups unbleached white flour
Resift into a smaller bowl with:
1 tsp. baking soda
1 tsp. ground ginger
1 tsp. ground cinnamon
Stir into the wet ingredients; beat using electric mixer (on low) until smooth, typically 2 minutes. Pour into the baking pan; bake for 45-50 minutes, or until a toothpick comes out clean. Cool on a rack. Goes very well with fresh blueberries.
NOTES: 1) This is an adaptation of "Fort Atkinson Gingerbread", a recipe dating from 1870 that was published in Betty Crocker's Picture Cook Book (McGraw-Hill/General Mills, c. 1950).
2) The crucial ingredient in this recipe is the spreadable butter, which is actually 30% canola oil; I haven't found any other fat that works as well. (Shortening makes it too crumbly, regular butter or stick margarine too heavy.) For a long time I used Canola Harvest soft nargaribe, but it seems to have disappeared from local groceries, and the producers aren't answering their e-mail. If you try a margarine (which I no longer recommend for the gingerbread) It's vital that the margarine is really margarine, not a "reduced-fat spread". These are partly water, and don't work for baking. If you're not sure about a particular product, check the nutrition label; real margarine has 11 g. of fat per 1 tbsp. serving. But the spreadable butter works best, has no trans fat, and less saturated fat than regular butter.
3) The egg replacer makes it safe for me (I'm allergic to eggs) as well as cholesterol-free; you can get it at most health-food stores, including Whole Foods.
4) Do sift the flour; modern flours are indeed pre-sifted, but are denser than flour you sift on the spot. This is an older recipe, which means the measurements were designed for sifted flour. I use King Arthur Unbleached; Gold Medal Unbleached works well too but is usually more expensive.
5) You can double the recipe and bake it in a 9x13" pan; this takes longer to bake and produces a high-rise gingerbread.
- Christmas, 2004; revised Christmas 2005; revised again Christmas 2007, Christmas 2008, and September 2010 -- but I've been making this recipe for nearly forty years.
Peace,
Paul
2 tbsp. sugar
2 tbsp. tap water
1 cup boiling water
1 tsp. baking soda
Peace,
Paul
