I printed the info from the lundahl site , there is two windings on the primary ,
but i just went with the 1:5 version of it .
If you can't find it , i'll look for mine , just a matter of tying pins together ,
if you pick up a strip of copper clad perf board that will secure the xfmr
when you solder it , careful as the pads may be close to each other
and that you don't accidentialy ground the the perfboard to the case
[ if at all , it should go back to the i/o ground bar ]
regards Greg
