Great RIVER MP2 Finished!
AW_music
Italy
here is our new toy.
Habby birthday!!
Great work done by Mata_Haze!!!
Thanks to:
Ptownkid for the kits
Okgb for the suggestions and help
Neeno for the Irons
:thumb:
Nice Work ! Should make Dan proud !
If you haven't added one , a 1/4" unbalenced out is a nice option
i used mine like this for years , driving a hundred feet on classical
stages at times with no problems .
When i made a quad i added a couple of jensen outputs to two
channels and they indeed added a little thickness but for purity
i'd go with the unbal outs
A secret circuit developed by Mata_haze that take care of peak levels!!!
:shock: :grin: :cool:
AKA --> Peak Driver! :roll:
[quote author="AW_music"]A secret circuit developed by Mata_haze that take care of peak levels!!!
AKA --> Peak Driver! :roll:[/quote]
Do tell, more info... :thumb:
Beat me to it! Just starting to test mine!
Great job! I think we all want to know if by Peak you mean the LED is a Peak LED rather than an "ON" one. Is it? Doesn't the original PS have an output to drive peak led?
jim
the Dan power supply as in the gerbers does have a comparitor
[ sense both pos & neg waveform ] as a peak l.e.d. driver
works well , starts to glow slightly as you approch the level
I.C. driven
Which output xfmrs did you use ? are those the smaller steel
" api " type ? regardless you should notice a big difference
also running an unbal out [ can use also as a non -latency out
for computor recording ]
Greg, do You have the gerbers for the PSU?
Can't find them anywhere, just the gerbers for the main card...
It would be cool to have the PSU-PCB with the peak meters to go
with the original MP-2 PCBs from Ptownkid.
Is there any possibility to have them made?
there's a real need for a peak led meter board. Something showing -6db, -3db,0db and +3db. Maybe even leave out -6db. There must be something around already.
anyone have any ideas?
jim
[quote author="Sredna"]It would be cool to have the PSU-PCB with the peak meters to go with the original MP-2 PCBs from Ptownkid.
Is there any possibility to have them made?[/quote]
if there's demand, i can do it on the new run of grs
I'll dig for the gerbers , the original psu pcb uses surface mount
ics for the comparitor , but one could copy the circuit though
in practice the one l.e.d is fine , you can hear it as it distorts , not
horrible and plenty of warning usually
So here's a question Greg. I think its still on subject. I'm curious as to why the circuit is in the power supply and not monitoring the audio signal itself?
The circuit is sensing current draw? Is it that linear that you can tell when a peak is reached? I don't see how it can do this without actually directly monitoring audio?
Just very curious about this.
And yes 1 led is enogh but its nice to see when you get close as well. On my board my peak led lights up with increasing intensity as it approaches 0db and full on when past it. You get a real "feel" for the signal this way.
jim
Itr may have been an " addition " that as you can see there is no room
on the preboard , so restate the main reason , otherwise the power
connector has an audio line coming off of the pre to feed the comparitor
nothing to do with the psu .
Could drive a meter seperately if you needed but is the beauty of the
pre set the gain and enjoy , effortless
regards Greg
Thanks for sharing!
I didn't understand the led-driver part of this build
( http://groupdiy.com/index.php?topic=20333.msg702314#msg702314 )
but now things are clearer to me :)
