Greg,
Nice job on the parts lists. I did find one discrepancy in the BOM for the GSSL that is handled by minimum purchase requirements, but I thought I would point it out in case others are sourcing their parts from other places. The Gyraf PCB requires 10 of the 100p ceramic caps, not 9 as listed in your descriptionfor quantity needed.
Also, Jameco www.jameco.com sells an Alpha 2 pole, 6 position switch with solder tabs for $1.35 a piece (part number 101573) that works well for the HPF Sidechain circuit. I like the Alpha with solder tabs a little better than the Lorlin with solder tabs, and they're cheaper! The only problem with the Alphas is that you cannot change the number of switch positions like you can with the Lorlins. But in this case it requires 6 positions for the sidechain switch, so it works fine.
