hugo said:
Is it possible to make this mod on a P2P La-2a to make the noise lower ?
Hi Hugo, unless someone more senior disagrees:
Grid stoppers act with the input capacitance of the tube to create a very high frequency low pass. They potentially eliminate oscillations and radio interference. Unless the resistor value chosen placed the roll-off in the audible range (no one would desire that) the typical hiss etc. will pass right by the grid stopper.
If a person is looking to minimize noise in a P2P tube build, the historical solutions are several, just to name a few:
Circuit flow- sensitive preamp stage far from noisy power stages.
Component layout- Some true point2point tube gear can sound incredibly quiet even though it looks messy. A tried and true circuitboard layout can be easily as good.
Lead dress- lead length and preamp signal leads being shielded and crossing noise emitters at right angles or with distance.
Tight heater layout- which removes hum
Transformer orientation- to find the flux null so the PT is not picked up in the OT etc.
Metal film resistors-lower noise
Known good tubes-selected for low noise
Shielded transformers- for super bling
hope that helps! my $0.02
I've built over 25 tube "things" now, and just completed my P2P LA2A.
no grid stoppers, and it is extremely quiet, no hum, very slight hiss if output cranked and no signal (aka listening for it at the noise floor)
you may know all this and are asking still and someone may have different input i'm not aware of.
Andy
