andre tchmil
What if I put different modules each with their own small casing in a bigger case?
For example, take two API preamps with their metal frontplate, together with 2 Telefunken V 676 (again with metal frontplate) and 2 Neve 17272,
Put them in one big case, so the grounds of each module is interconnected, right ?
the OV of the 2X20Volt (api) is also the Ovolt of the24 Volt (V676) etc.
Note that each pair of modules has its own seperate PSU, so only the O volt gets joined via the chassis.
