groupDIY 500 series mechanical specifications
sorry for the confusion, GndB is Power Ground....
pin 13 of Edac Connector.
GndA is pin 5.
till now I haven't had any problems connecting both GndA and PwrGnd at 0v
also for xlr pin 1 using GndA, and safety Earth to chassis only, just for testing its behavior
signal is very clean and also the last module plugged close to psu presents no issues
I apologize to everyone if my questions and requests are in a post where only mechanical infos should be shared
but I think it is useful for those who want to go for a psu like this in a DIY lunchbox and so don't make any mistakes
best
No case for an apology.
I am glad that it is working fine.
In my limited experience , a kind of mechanical connection "standard" between the front panel and L bracket or something similar would help a lot with alignment issues and the odd potentiometers sticking out. It seems like an L bracket is kind of a luxury in the DIY 500 series world
Since the front panels have limited real estate , having nuts visible is not the prettiest of sights. Some knobs definitely cover those but others barely do
Seems like it would be a relatively easy undergoing for someone here !
Here you mean the backplate on which the PCB is mounted and the fixing between the backplate and the front panel (which we call faceplate).
On our modules the backplate is fixed to the faceplate through threaded inserts/standoffs that are inserted into the faceplate. You can not standardise such fixing as the locations of the standoffs will be dictated by the front panel layout.
sort of dumb 500 series question.
What sides should the card edge pads be on for a module? I'm assuming best would be both (with a via from top to bottom pcb).
but does it matter as most racks seem to have pins on both sides of the edge connector socket?
Always have it on both sides for reliability. It does not cost extra unless your design is particularly single sided.
Also do not omit any fingers. This again does not cost extra. I have seen a number of modules with fingers missing (for example PIN 3, 7, 9 and 11). Very bad design decision.
[What sides should the card edge pads be on for a module?] -- BOTH SIDES!!! ..... In today's world, there is no such thing as a "single-sided" PCB. Long ago.....YES!!! Today???.....NO!!! And, if you were to design and have fabricated a "single-sided" PCB, it would start-out as a "double-sided" PCB anyway and then the fabricator would have to etch-off all of the copper on one side and watch the copper wash down the drain!!! Not only THAT, but.....you're still paying for all of that copper that is swirling down the drain!!! Howz dem apples for ya???.....
So.....just go ahead and design yourself a "double-sided" PCB with edge-fingers on both sides. Then, right where the tracks terminate into the edge-fingers, place at least -- TWO -- vias right there to connect both sides of the edge-fingers together. In fact, you could go ahead and place 3 or 4 vias right there, not only to have some redundancy, but to also lower the overall total via resistance and inductance as well. In one sense, you need to think of the via "barrels" as being like resistors. Due to the tiny drill-hole size, there's a resistance right there. And, just like any parallel resistors, the more you have in parallel with one another, the lower the total resistance value will be.
When I am running fat "Power & Ground" tracks on a PCB and I need to change to a different layer, I usually place at least 4 vias at the layer-transition point, not only to try and maximize the electrical energy transfer going through the vias to another layer, but to also reduce the overall via resistance and inductance. You gotta think.....the via resistance of using 4 vias is 1/4th the value of a single via!!! However, the major downside is.....there may not be the room available for extra vias.
The API way is to have the edge finger pads on the bottom. You can either do that or have them on both sides. Though I have heard of some racks that incorrectly connect the edac to only the wrong side.
The edge fingers should be hard gold plated which adds significant cost. I do not agree with the above comments that you should automatically just do both sides. It would depend on your own cost benefit analysis.
Yes I have seen them. Thank you very much for doing that. I am now just working out if I can print my own with a nice built in logo. Unfortunately they are too big for my current 3D printer. I may have to upgrade it. Work in progress.
>> Speaking of -- STL -- files.....I thought you would find this unique website to be of interest!!! The link I have included below goes to a website-page that contains nothing but -- 3D-printable STL-files -- of mixer/mixing-console fader knobs!!! How does THAT grab ya???.....
By the way.....I have attached an -- STL -- file of an ALPS mixing console fader knob to this response. The actual name of the attached file is: ALPS -- Fader Knob - 3D-Printable.stl and all that you need to do is to remove the ".pdf" file extension.
https://www.stlfinder.com/3dmodels/fader-knob/?page=1
  • ALPS -- Fader Knob - 3D-Printable.stl.pdf
    1.2 MB
[I do not agree with the above comments that you should automatically just do both sides] -- I was merely trying to point out that even if you only want a "single-sided" PCB.....you're -- STILL -- going to pay for a "double-sided" laminate, because the raw laminate vendors don't make or supply "single-sided" laminate material anymore!!! So, as I had written, if you want a "single-sided" PCB, you're -- STILL -- going to pay for a "double-sided" laminate and the PCB-fabricator is just going to completely etch all of the copper off of one side in order to provide you with a "single-sided" finished PCB. That's all.....
So, in my ignorant opinion, if you're going to end up paying for the copper on both sides of the PCB-laminate anyway, then you just might as well use it and go ahead and design a "double-sided" PCB. But.......................what do I know about PCB design, right???
I buy single sided laminate, and it is less money than double sided? I am lost here I guess.
It's been eons since I paid attention to API's edge finger protocol (if I ever did <g>) so I looked at pix at Sweetwater. They have 360 degree views of modules for sale and indeed the fingers are omitted from the top side of the board....not that I was doubting you, John! I was merely curious how they did current production.
I guess those fingers on the top side didn't pass the cost-benefit analysis for their pricey modules. <g>
Bri
[I buy single sided laminate] -- Yeah.....you're right!!! I keep on forgetting about the different worlds that exist between what goes on here in this forum and the company's that I typically have to deal with. I don't know from who or what you are buying single-sided laminate material from, but the large PCB-fabricators that manufacturer PCB's for the aerospace/avionics companies, defense contractors, medical electronics firms, etc. that I usually work with, they just don't have the time nor do they even want to expend the effort of dealing with "single-sided" laminates because no major electronics business ever designs any "single-sided" circuit boards anymore.
The companies that I assist with the design of their PCB's, their circuit boards usually involve 6- to 20-layers, 3- or 4-mil tracks and spacings (now, it's getting down to 2-mil tracks and spacings), hundreds if not thousands of vias (prior to the COVID-19 scenario, I was working at a defense contractor and in one of their engineering meetings, they were "celebrating" a new avionics jet-fighter PCB-layout that had been just designed with over -- ONE-MILLION VIAS ON IT!!!) and itsy-bitsy/teeny-tiny Surface-Mount components down to -- 0201 (20-thousandths X 10-thousandths or 0.020" X 0.010") -- in size. These parts are jokingly referred to as being called "Gnat-sh!t".
I need to keep more in mind about the significant difference in technologies between what normally takes place here on this forum and what it is that I am typically involved with otherwise. Please accept my apologies!!!.....
You read my mind! I was just thinking that fader knobs would be a good 3D print job. I was contacted the other day by a customer who has nearly completed the build of an 8 channel tube mixer based on my EZTubeMixer design. His build is almost complete. All he needed was 8 T-bar fader knobs. P&G ones from Carnhill are nearly £5 each, a ridiculous price. I have quite a few in stock so I sold him 8 for £8. Then I thought, hang on a minute, surely I could 3D print these?
So thank you very much, your post is very timely. I will try printing one today.
