[quote author="gerardmanvuca"]I'm totally new to the game, I have read the 146 pages in the SSL Thread and have not found the answer to my questions.
I have a few questions to ask:
- Which way do I put the small caps into the PCB? There is a ''.1'' sign in them.
- Which of all components have a polarity difference?
- I have posted this question already but i thought i would add it in here, just need to know what wires to purchase to tie up the (pots and lorlins) and also the XLR's.
thanks for the help.
[/quote]
There are a few small caps so be careful to not mix them up. The .1 are not polarized so it doesn't matter which way you put them.
Polarity MUST be observed for all the electrolytics. Usually the negative side is marked and the positive side has the longer of the 2 leads.
Also your diodes must be inserted the right way. Oh yes the rectifyer and the ICs including the VCAs all have to be inserted in the correct way.
For wire I bought some 24awg multistrand as well as some 22awg. you could use individual wire or ribbon cable of 10 or more wires (just remove the excess ones) for connecting the switch board to the main board. I am doing my own panel design so I can't use the switch boards and have to wire those as well. For the XLR I'll be using shielded wire like mini mike cable .
Hope that helps and I didn't leave out anything. (be careful with the polarity. If you are not sure don't solder them in and hope for the best, come back here and ask until you are positive.) Try looking at pictures of successful builds.
I am getting close to finishing my wiring as well and its getting exciting.
Have fun.
jim
