[quote author="RogerFoote"]With 2180s you don't use a symmetry trimpot. With 2181, you do.
The way I learned to measure distortion from old dbx literature is to feed a 100 Hz signal at nominal level into the compressor and look for the 2nd harmonic component on a sectrum analyzer. So, look for a peak at around 200Hz, and trim until it is at the lowest amplitude you can get.
If you go past the "ideal" spot, you will notice the 200Hz harmonic start to rise again and you then know to go the other way with the trim pot.
I don't have a hardware spectrum analyzer anymore, so I use a plug in called "Periscope" from AudioEase on my DAW to measure with.
It is probably best to use a 24 bit system for this. Mine is a "typical" MOTU setup with a Lucid AD9624 for input. Nothin fancy, but very usable.
Hope that helps (a little)[/quote]
Is this a good method for setting the 50k dist trimmers? I don't have a scope, only a VOM.
So, besides the dist. trimmers, I still have to calibrate the side-chain (Th med & Th loud), and the meter. I think I have the info for those.
Guess one of these days I'll have to buy a meter for better calibration.
