guitarguy12387
Aha! a 1k works. Thanks guys.
stereokillah thanks for helpstereokillah said:guitarguy12387
check this link http://www.kpsec.freeuk.com/components/led.htm
it's bester to make the led in series and like Harpo explain you can find the good resitor value for your Gssl
check your voltage in your control board where you should put you wire for the led and you could do your calculation
SIXTYNINER take the +15 and 0 on the wire transformer directly before the Board with resitor in series with the power led and meter led like harpo said.
from page 1 of this thread you want a 1mA fsd meter (or even lower, like 100uA fsd with additional resistor).audiophreak said:Can a modification be made so a 100ma meter can be used in the GSSL? I've only gotten to page 55 of this thread and havent seen anything on this yet.
Hi damien,damien said:Hi,
Anyone could give the correct slow-blow fuse rating ?
thanks
