GSSL HELP THREAD!!!
Hi everybody :).
it's been 17 years since last post on this thread...
I'm having a look at a ssl-clone-comp that i bought some years ago.
I haven't used it yet,
but would like to, now.
I have that hum problem, and would love to get rid of it.
Here are some pictures.
The rear side of main PCB has been adapted, that's obvious...
Would anyone have anything to say about the way transformer has been soldered ?
Thanks, very much, for your help :)
Mat
I moved this for you...
Some janky looking stuff going on in that transformer area. I'm not familiar with this project so maybe normal stuff. Some of those through hole blow outs look suspicious and I would verify circuit continuity where it should be...
The xlr connectors look funky . Any chance for some less blurry pics of the wiring there?
Hi!
So, i started the GSSL project about a year ago, as a project to do from time to time. Power transformer rated: 17.5-0-17.5v, VCA: 2181A pre-trimmed. I "finished" it somehow but i have some problems:
1- first time powering up, hooked up to my soundcard: some huge hum, no sound passing. I checked the GSSL thread, corrected the ground to the xlr pin 1 to chassis, turned arround the toroidal. Opened back the comp, the hum was gone, still no sound passing.
2. I removed all the chips from the pcb and started to measure. I got the following:
a)- LM7915: in- 38.76v, out: 15.09v- getting hot, normal i suppose...
b)- LM7815: in- 6.3v, out: 0.002- not good, i suppose
c)- Op-Amps:
- NE5534: pin4- -15v, pin6- 0v, pin7- 4.87v, pin8- 2.7v.
- NE5532: pin4- -15v, pin6- 0v, pin7- 0.05v, pin8- 4.8v (sometimes rising to 8.5).
d)- TL072: pin4- -12v, pin8- 3.43v
e)- Traces to VCA: right VCA- -15v, left VCA- 6v
I read that LM7815 is hard to kill, so i checked for cold soldering, it is not the case, as it's well soldered.
Also, before assembly and turning the unit on, i checked about 4 times for bad soldering, cold soldering, soldering joints. It was all good, otherwise I would not have powered the unit.
I'm thinking about changing the LM7815, but I don't know what caused it to stop working, I don't know what to do next, what to look for...
Can you point me to the right direction, please?
TIA!
We can only guess.
- regulator latching
- exotic switches with LED wired wrong
- IC inserted with wrong orientation
- solder bridge
etc etc
As a rule, always measure voltages at sockets first before inserting any IC. If you used IC sockets, can still do.
No LED's on switches. Lorlin switches, IC's are good oriented - triple checked, confronted with other pictures in this thread.
No solder bridges, also checked 4 times.
I'm thinking about swapping the regulator, and do a second round of measurements.
As for the switches, it matters so much the wiring? For example, i have Lorlin switches as i mentioned above, but for dual poles i have A-C, not A-B as stated on the schematics. Of course i wired it by poles, also keeping the numers as by schematics. Should this be a problem?
... Power transformer rated: 17.5-0-17.5v,...
b)- LM7815: in- 6.3v, out: 0.002- not good, i suppose...
A 35VAC center tapped power transformer with primary winding hooked up for your romanian local 230VAC mains (primary winding(s) hooked up correct?) most likely ist not producing 38.76VDC in front of your voltage regulator. After rectification (VAC*1.414 - about 2*0.6V diode drop in rectifier) that would be an unlikely 60% regulation of an unloaded transformer on top to give out 38.76VDC (as well as exceeding the abs.max. 35VDC input voltage of the LM7x15 regulator). In respect to what exact spots did you measure your stated voltages (and are these AC or DC and signs matter).
Yes!
I have the following:
Transformer: 2x 115, connected together midle windings so I have 230V AC primary. In secondary: I have 17.5v- 0v- 17.5v, 530 mAh- AC.
I measured the voltages with 0V from audio input side, DC current- I read that on the thread also.
Yes!
Pinout of LM7815 and LM7915 is different. From your -38.76VDC and +6.3VDC numbers (assuming sign) that's a total of 45VDC in between rectifiers +/-nodes with 0VDC reference voltage in between, would be a more reasonable +/-22.5 VDC at each input of the voltage regulators. There might be a broken or misplaced/wrong orientation chip pulling the +15VDC rail down. Pull all opamps and VCAs and confirm voltage readouts of +/-15VDC supply rails again. A once powered opamp or VCA placed with wrong orientation will not have survived.
Here are some pictures of my pcb. I hope it can be seen the orientation of IC's. Partially before and after...
Maybe i've done some stupid things, i wouldn't say no 🥴, but for every step i did, i calculated my moves and read a lot, as I really like this comp.
For example, underneath the pcb there is a piece of rubber to insulate from the case.
Also, i isolated most of the wires, although it is just for testing mounted.
If I understood right what Harpo said, I'm starting to believe that the trafo is too big (?!) and burned my regulators...
I bought 4 sets of those today (negative and positive also 🥳), i will replace them and order a new toroidal.
I will order a custom one soon as I have near me a business that make custom toroids, so if you have any suggestions, I'm more than grateful:
- voltages (15-0-15?)
- current- thinking about 2 Amps (?), as i will try to add later some turbo, SCC and a vu-metter card
Do you have other suggestions regarding my situation?
Thank you!
Hello!
Do I have to replace tantalum capacitors of sidechain timing section if placed with reversed polarity? Should I change the TL074 because of this too? The 24Vdc supply for TL074 are stable.
Thanks!!
Thank you!
The hook up of your mains transformer looks questionable. Transformer primary wires black+green would be joined (and isolated in order to prevent an unwanted connection to your always safety grounded case) for european 230 VAC mains. In between the transformers outer primary winding ends and the AC mains inlet will be a fuse and a switch. The secondary winding center tap (green) seems to be connected somewhere not shown to a white wire, further going to the center pin of an unknown connection pcb, continuing with another connection of a brown wire to reach the center pin of the AC inlet on gssl-main pcb. The transformers outer secondary winding ends (both white), further going to the connection pcb by a gray and a black wire, continuing with two connections to a black and a red wire to reach the outer AC inlet pins on main pcb.
Please check for continuity (zero ohms) of the transformer secondary center tap arriving at the center pin of your AC inlet/0V reference voltage on gssl-main pcb, as this might be broken somewhere in between or has a broken trace close to the AC inlet on gssl-main pcb, causing your -38.76VDC and 6.3VDC instead of +22.5VDC / -22.5VDC readouts.
Your transformer seems to be OK for this task.
The jumper or capacitor at the HPF-provision is missing on pcb, interrupting signal flow.
I did some measurements as you said:
- transformer secondary resistance , also voltage again, removed from pcb:
a) first white wire- center tapped- 3.3ohms disconnected from power, 18.7v- power connected
b) second white wire- center tapped- 3.2ohms disconnected from power, 18.7v- power connected
c) first white wire- second white wire- 6.1 ohm
- Pcb: center tapped- 0V input reference: 0.4ohms
As a small detail that i don't know if it's gonna make a difference: all regulator are Texas Instruments except LM7812 wich is bought from a small vendor near me, i suppose it's from China, don't know the manufacturer... maybe this one faild the first time powering up the unit and burned, leading to conducting negative to positive rail... Just a thought...
It is possible?
Thank you!
Hi! I've fixed the problem the following way- many thanks @ Harpo!!!: transformer 0v tapped center didn't give me 0hms at measuring from 0v reference at input (sometimes worked, other times didn't, so i reflowed the traces from transformer to the pcb). I've fixed that, my -15, +15, -12, +12 rails are all good, but, while at it i considered measuring opams sockets and vca sockets. All good, all voltages are ok according to the attachment (found on this thread- i know it is another version, but the orientation is still the same), except the output of the opamp socket ne5532, pin 6, where I have -1,1v, and -0.8v (all others opamps, on pin 6 I have 0V). I've read that should be close to 0V (how close? And negative voltage?) and now I'm asking myself if it's ok to put the opamps into the sockets and power on the unit "live" for audio testing. I've looked, all traces under the pcb are ok, no solder bridges, no continuity whatsoever.
I should put the IC's and power on?
I really don't want to burn my opamps, help! 😊🙏
Many thanks!
  • gssl voltage test points 2.pdf
    294.5 KB
Note orientation of each opamp. Specially that one of the vca's is oriented the other way around. Mounting wrong and powering kills ic's.
So, I should mount the IC's and give it a go? Even with output voltage being close to -1v, at pin6 on both opamps?
Hello, I've been searching for days now and there is an option paralysis because there are too many diagrams floating about. Some are even diagrams of mistakes.
Can someone please help me with wire diagrams for main board+superside chain with power+bypass(compression) DPDT buttons.
My head hurts 🤣🙏
