Hi guys,
I'm quite sure my GSSL is not compressing correctly, because no matter how loud my input signal is, and with the threshold position at 100% CCW, the output signal will always be 1dB-3dB down for 2:1 ratio, 3dB-4dB down for 4:1 ratio, and 4dB-6dB down for 10:1 ratio.
Playing around with the timing controls only varies the gain reduction by 0.5dB to 1dB, for an example, if at 2:1 ratio 0.1ms attack 0.1s release i get 2dB gain reduction, switching to 1ms attack, i may get 1dB gain reduction or no gain reduction at all.
Compression also only kicks in when the threshold is turned to 95% to 100% CCW (when negative DC voltage appears on TL072 pin 1). If I mounted the 47K resistor to reduce the sensitivity, at 100% CCW, I got no compression.
Some DC voltage measurements:
Supply rails -15.47V / 15.43V, -12.24V / 12.25V
TL072 pin 1, threshold CCW -3V, threshold CW +3V (unaffected by other controls)
TL072 pin 7, makeup CCW -1.90V, makeup CW 0V
Can't test for AC voltages, because my DMM don't read down to mVAC.
Traced for continuity and didn't find a short circuit.
Checked for cold solder joints, and found none.
Replaced the TL072, TL074, THAT2180, and I still get the same result.
Checked for lousy capacitors, and found none.
Resistor values are also correct.
Another problem is the auto release (2.4s) timing. It distorts the output signal.
Weird thing is, regardless of these problems, the compressed audio still sounds great. When I played around with the controls (leaving threshold at 100% CCW, and ignoring auto release), then comparing with the audio in bypass mode, I definitely heard the differences.
Help!!!! :'(
