Hello, I am just finishing my GSSL and have two questions, though first of all: big thanks to Jacob for making all those ressources on the ssl comp available to the public, this is only my second diy project and I am really happy with how it's turning out to be...
1. I would like to use a 6 volt power indication lamp like on those old Fender guitar amps instead of the red diode on the control pcb, what is the best way of powering this? I also need to apply 12 volts to the lamp on the vu illumination - any hints? I have a really beefy PT (80 Watts - don't ask
so would it be best to hook up to the PT output and set up an extra little board that will give me the correct voltages? has this been answered before?
2. Is it possible to get the gain reduction on the vu set up reversed way, as on an 1176, for example? I got a Sifam AL29 I'd like to use for my Compressor...
I just "completed" the project this afternoon and have done a short listening test, which was very pleasing
I will comment on sonics in detail later, as there are still some things to do, I want to change the threshold range, as all the action is happening on only about one-fifth of the pot range. Then I must adjust the ratios, and the frontpanel is still in work, and... there is a lot of work to do!
