How do you know it's GR and threshold related, and not just a general gain/loss problem, or no compression, or your SSC filters?beatnik said:on the return of the compressor I have 5dB difference between compression in or bypass.
and the meter shows gain reduction, so I think compression is happening and it's not just volume decrease
i tried to disconnect the super sidechain board and put the two 47K resiistors back on the main board, but what I got is there is even more gain reduction, about 10dB
Your results do seem to suggest a very low threshold. When I had a problem like that it was simply due to a faulty threshold pot going intermittent.beatnik said:ok i did the check with all the three ratios and the values are so wrong! there is obviously a problem there.
keep in mind that I've taken out the sidechain filter circuit for now
There seems to be too much load connected to your +12V rail, causing the 78L12 going in self protection mode. Did you connect any additional parts (status LED's, incand.bulbs, relais, iluminated switches, meter ilumination, ..., cigarret lighters) to this rail ?beatnik said:voltage on F point varies from -12 to +4 Volts so there's a problem here. I try to replace the pot and see.
Only parts difference from datasheet is temperature range and input offset voltage. Both parameters don't matter here (except you want to operate it at arctic venues). More likeley your TL074CN was broken to begin with or maybe IC pins bent inwards, so didn't make connection to IC socket.then i noticed a strange thing. different behavior between different types of TL074
with the TL074IN I had in there, we know whats happening.
but I tried to replace it with a TL074CN and... no output!!
check for broken trace and solder connections around/at TL074 socket, parts and ribbon cable connector. One opamp stage might be running open loop, causing exessive control voltage for your audio VCAs.... output goes down about 40 dB, like threshold goes even lower
Transformer is AC, the usual suspects want DC, but my cristal ball is a little blurry what your circuit behind might be.beatnik said:.. and a combo of vu meter and bargraph led to do the metering. They have their separate 12V regulated taken directly from the power transformer secondary.
hopefully. Already tried my latchup fix for the +/-12V ?However, there is a latch problem on the +12 regulator, I've ordered a replacement from a different brand, hope that will solve the problem...
I need a better cristal ball ...One last question. Right now I have the vu meter to show output level of the L channel.
How should I do to display L+R?
there need to be more on this whatever it is board or your 7812 won't surwive the every next halfcycle reverse polarity from transformers AC voltage.beatnik said:There is a led meter driver board which has a 7812 regulator on it, then I bring 12V from there to vu meter, relay, illuminated switch.
http://www.groupdiy.com/index.php?topic=47.msg626822#msg626822I'd really like to know your option and try that before changing regulators. Do you have a schematic maybe?
rainton said:So here's the thing: As soon as I patch the GSSL in the chain the sound drops a little (level wise) and gets duller and less defined - kind of a high end roll-off
This also happens when the rotary switch on the front panel is switched to "bypass". (the bypass is actually working)
Actually the whole comp is working - it's compressing and all - it just doesn't sound good (anymore)
No schematic attached, but should work. Your wording was 'taken directly from the power transformer secondary' and that would likley let the smoke out.beatnik said:In the attachements I've posted the power supply portion of that board. I'd really appreciate your opinion.
The 7812 regulator takes the +/- V from the main GSSL board, post rectification. It's kinda the same as the main GSSL regulators are connected, so I though it was ok.
my pleasure. Did the trick for some members, but might not work for all brands of Vregs.Thanks for your anti latchup fix, I'll try that today.
No. Just don't power on/off while listening or mute/turn down your monitors. ITB plugins don't do this, because when activating there isn't any real world cap to charge or rail voltages to be stabilized and when deactivating there isn't any cap to drain from not equal current demand of the different +/- rail voltages. Active hardware unfortunately suffers from these shortcommings. A workaround for this would be a hard bypass circuit by means of some relais that could only be activated for normal/usual operation until a timer circuit after some seconds enables the relays control voltage. Switching the unit 'off' would immediatly cut this control voltage, setting the relais back to their hard bypass mode again.I also have another strange thing, every time I power on/off the compressor there is a spike in the audio path.
Maybe it's related to the regulators latching?
Maybe are you sending unbalanced signal to the GSSL?
The 100nF caps in front of the 7815/7915 are already shown in the schematic, but are in front of the 78L12/79L12 on pcb instead.
