Jimmy1980 said:
I'm still working with my clipping output problem. Just wondering if anyone knows if a bad TL072 or TL074 could be the source of the problem. All DC voltages look good on them, though....
maybe, but questionable with your measuring methods.
When the compressor is powered off I can send 0.775vac (1k tone at 0dbu) from my DAW and 0.775vac will show up on the output XLR pins (I'm not sure if this should be happening).
Some Kohms additional impedance, but signal will make it from input to output in this circuit. The internal protection diodes inside the opamps (not all opamps have these) hopefully will prevent damage with input voltage (your signal) exceeding the chips supply voltages (nada with missing power supply).
When the power is on I'm getting about 5vac at the XLR output pins. This confuses me as it seems like I'm getting a much louder signal on the output compared to the input. Could this explain why everything I run through it sounds distorted?
5VAC at XLR-out-pin2 and/or pin3 in respect to 0V reference voltage or between XLR-out-pins2/3 ? Lots of reasons (wanted or unwanted) to get there.
When the compressor is powered on, I can trace the 0.775vac cleanly to the left and right 2181 IC's in the VCA sections where I find a slight bump up to around 1.1 vac on pin 8.
The VCAs are current-in/curent-out devices, not voltage. You fitted these VCAs with correct orientation? They won't survive, once powered reversed.
These are my approx VAC readings at my output NE5532 pins from my +XLR pins
maybe a language thing, but I would want to know the opamps AC and DC voltage readouts in respect to 0V reference voltage, not in respect to whatever +XLR pins.
I removed the 2180's from the left VCA section and jumped pins 1 and 8, which made the left channel sounds great but no compression.
With the VCA (with changed type) bypassed, the controlling element is missing, so no compression happening is correct. Clean audio with audio-VCAs bypassed as well shows input and output section probably operating correctly, so fault will be located in the sidechain section including its +/-12VDC supply or the audio-VCAs might be broken. (please be more exact with your numbers. What type of audio-VCAs and sidechain-VCA are on board for real, THAT2181 (A, B or C) or THAT2180 (A, B or C) ?
I'm getting continuity between pin 2 of the sidechain's 2180 and the 470R.
Checking for continuity might be useful for sorting non-coded multicore wires, but you almost never use this multimeter setting for any electronic devices. Use the 'Ohm' setting for measuring resistance. A short will give a zero or close to zero readout (your measuring leads and pcb traces have resistance as well).
I'm only measuring about -2.8v dc at pin 5 of the sidechain 2180 when I believe I should be measuring -15v dc
There is a 5K1 resistor between the negative supply rail and each audio-VCA-pin5. With no signal, -2.8V at 2180-pin5 is close to perfect (for the audio-VCAs, powered from +/-15VDC rails. The sidechain-VCA is supplied from +/-12VDC with a 3k9 resistor in between -12VDC and VCA-pin5).
Question: When I send 0.775 AC voltage (1k tone at 0vu) from my DAW and trace the voltage through the PCB, I've noticed I can measure 0.775 AC at ground. Even on front panel of the chassis. Is this normal?
So your case ground is connected to 0V reference voltage and you mixed up probe wires.
Use your black wire probe that is plugged into your multimeters [COM] terminal for the 0V reference voltage connection (the center pin of the aux.12V relay/lights connector might come handy) and keep it there for nearly all measurements (except FI when measuring transformers primary or secondary voltages). You probe around with your red wire probe that is plugged into your multimeters [V/Ohm/...] terminal and your multimeter set for AC volts or DC volts in a range higher than expected.
