Hi Everyone,
I'm trying to figure out how to wire up my GSSL/Turbo/2 Super Sidechain project. I bit off a bit much I suppose
I've read (most of) the posts here and saw Harpo's drawings, etc... My question (while a novice question) is whether or not I need to connect both Super Sidechain boards "Com/On/Off/Pot A/PotB" connections to the back of the control board or if I can just connect the left SSC board connections and leave the right SSC ("Com/On/Off/Pot A/PotB") disconnected?
Also wondering if I use the "In SW "to" and Ret" and LED connections on just the left side SSC board to connect to my "Compression" on/off front panel illuminated switch or do I take it from the control panel and leave these disconnected?
I know a lot of this has been covered but I haven't found any definitive way of wiring these connections and I'm a bit confused (clearly
My front panel has 2 illuminated switches. TURBO and COMPRESSOR. Each has a DPDT switch and LED "+ and -". I'm trying to wrap my head around wiring them up with all the boards. Any help would be appreciated.
Thanks in advance!
Matt
