check for shorts, components and breaks, then check again. If you read back through this thread, you'll find that the problems comes in these categories.
Jakob E.
Jakob E.
Check that you have -12 to +12V at one end of the 220K resistor when varying threshold. Check that you have approx. 0V at the other end of said resistor (as it's a virtual-ground coupling).
This is only good for initial check, tells us only little about circuit intergetyAll voltages measured without IC installed.
i do wonder why the voltages for pin 6 on the SC VCA was 3.3v and falling and why Pin 6 of TL074 was 3.9 and falling
