mfdu
those switches are pretty easy, because they simply are on, or off.
is the switch a dual row of three prongs?
the middle of each row simply conects to the outer prongs when switched on. cant go wrong.
but i have.
units not passing audio. chased all +/- 12 and 15 - all there. yet to chase 1kHz through the circuit.
got a couple of points where there is -0.85Vdc on the VCA 5534's , 13.67Vdc and 1.64Vdc on the output 5532's and -0.61Vdc on a pin each of the input 534's
tl074 shows 0.22, -0.15, 0, 0,0, 0, -12.15, 12.10, 0.1, 0, 0.02 , 0, 0, 0
(phew is that all?)
all voltages match each side, the 12V is stable as. but no signal passes.
tried disconecting the control board but no change.
have not tried changed 5532/5534's because they are showing the same volts and stable.
i know next step is chase the signal to where it stops, but any one (gyraf?) got a tip?
chris.
but i have.
(phew is that all?)
chris.
