hi...
i have a noise problem with my gssl (rev12)
erverything works fine, but there is a audible noise on both channels...
i searched alot the in the help thread and tried alot of things but i cant find the failure...
i use the cool audio 2181 and changed the 1m Resistor (Rsym) to 150 k ( https://www.coolaudio.com/docs/COOLAUDIO_V2181_DATASHEET.pdf)
- i did Star Grounding
- i put a filter pcb between the transformer and the pcb (CRC Board)
- i put a jumper between pin 1 and 8 of the vca`s and getting a clear signal with no noise...
i read post #8283 and he said that the 2181 and the 2180 is the same chip.... so i tried to use the 2181 as pretrimmed ones and lifted the 150k (RSYm) resistor so that i have no connection between the distortion trimmer and pin 4 of the vca`s ...and all noise is gone but now i have a distorted output :-(
so i think i get the noise from the distortion trimmers ....what could now be the problem ? i have +15V and -15 V on the legs of the trimmer
i get only clear not distorted sound when the trimmer is set nearly to the middle position (0,88V) ....but with the noise...!
when i move to - it is getting distored but no noise and when i move to + i got no sound
i hope you can help me...this is one of the last things in my box of shame which still is not working...
i tried to find the failure for a long time but now i think i am near to it... the noise comes from the distortion trimmer side but why ?
thank you ..Heinz
