What kit..??
Beeswax said:Seeking feedback on my power wiring for 110V. Is this looking correct?
AC mains voltage isn't a constant and might vary by +/-10%, depending on location or time of day.Beeswax said:Is 18V too far off the 15V it's intended to be?
Traceside of pcb will tell you, there are only 3 different connections. If you would use screw- or crimp connectors, these 3 needed connections (2 outer ends and the center tap connection of the transformers secondary windings) come with a 0.1" or 0.2" pin spacing, so the 5 drill holes assure, both type of different pin spacing connectors will fit. The transformers center tap connection always connects to the middle of the 5 holes.Beeswax said:Where in the build does in indicate which of the 5 holes these secondaries attach?
That was one reason, multimeters have been invented. Just ohm it out for confirmation ...Beeswax said:Harpo, it appears with center tap in the middle position, the two holes on the right share a trace while the one on the left is traced to the hole closer to center. (see pic)
correctBeeswax said:...With my meter set to ohms,
no, and from your pic the transformer isn't connected to pcb, so this wouldn't make much sense anywaydo I power on the unit
no. You want to measure resistance (your kind of measurement might measure the rare event of a blown mains transformer shorting to chassis/safety ground) in between -in this case- two spots on pcb.and place negative on chassis ground and positive to each of the contacts?
Lets call these 5 spots on pcb 1,2,3,4,5, the center for the transformers center tap connection being 3.Am I seeking a particular value to indicate which of the 4 (minus the center) the other two secondaries connect to?
so primary windings of your mains transformer would be hooked up in parallel and there will be mains fuse and maybe a mains switch in between your wall outlet and the gssl.I'm building for 110V.
Ricardus said:So it's hard to tell from Gustav's photo in the build PDF, but is the red LED just going on top of the meter?
