GSSL HELP THREAD!!!
On the other hand, I should probably use the built in SC.
So the question now is: should I make it permanent by bridging it, like Gyraf suggested?
yes, the wire link must be soldered in if no filter is used. otherwise you don't get sidechain signal.
Or should I connect it to my Turbo board and make it switchable, so it's only engaged whenever the turbo is engaged?
That's how PCBGRINDERS's blog is suggesting
3rd option will be getting 2x SSC boards and order a new frontpanel, drilled for SSC that has those 7 steps markings.
Some say though that SSC is not necessary when turbo is installed!?
I can't decide, don't know the pros & cons for one over the other.
I might even have confused myself further.... 😆
Thinking about those 3 options made me wonder some more.
If HPF* is bridged, then signal goes to sidechain?
Will it still low-cut? without a cap..
If not, then putting a cap right on the PCB and avoid the toggle switch, will make it permanently low-cut?
I remember seeing a 0,1µF cap between HPF* and toggle switch, in the guide.
I thought the cap was doing the low-cut.
If the cap is doing the low-cut, then what is the sidechain section doin?
I probably haven't understood it correctly.
Each compressor has a sidechain, controlling threshold, attack, release, ratio, ...
You are talking about a sidechainfilter. Have a look at the schematic.
Sidechain signal coming from TL074-pin7 thru a 22uF cap, followed by two 20k resistors, each to a virtual ground node of the following opamps, so being in parallel, giving 10k. This R/C filter forms a hpf with -3dB cutoff point at 1/(2*PI()*10000*22E-6)=0.72Hz with the additional 100nF hpf provision cap shorted out. With 100nF cap not shorted out by a maybe toggle switch, the 22uF cap is in series with the 100nF cap, giving cap value 99.55nF on paper, that is still followed by the two resistors to the virtual ground nodes, so the hpf -3dB cutoff point rises to ( same 1st order -6dB/oct filter formular with changed cap value 1/(2PI()*R*C) ) 159.87Hz for a 160Hz frontpanel label. A 220nF cap instead of the 100nF cap would have this hpf set at 73Hz, two 100nF caps in parallel instead @ 80Hz, .... just run the numbers and pick the cap value for your wanted hpf frequency.
Thats it, great, thank you! -that's what confused me!
Richardus asked me "don't you want sidechain option, its SUPER useful" when I asked about leaving the HPF* toggle-switch + cap out of circuit.
If leaving the toggle switch out (low-cut), I have to bridge the HPF* or else its not connected to the sidechain section.
And if sidechain isn't connected, that makes the compressor useless (if sidechain is in charge of threshold, attack, release, ratio etc.). Right?
But as you mentioned, if I understood it correctly, theres also a HPF at the sidechain section, right?
Going back, I also see that I've misunderstood Gyraf's answer.
I think im gonna leave the low-cut filter+toggle out and just bridge it,
because one: I don't have space for it on frontpanel, and two: I don't like having my low-cut filter at a fixed Hz.
I rather upgrade later on, with two SSC boards and have the filter toggle/control-knob on my frontpanel (option 3).
I looked at schematic, and even though I don't quite understand them yet, I saw the route you were talking about. I see what you mean.
Cut the potentiometer?
This is too long for my knob and I want to shorten it.
Is it possible to saw the tip (blue line) off or is there some mechanics inside that solid metal part?
    224.6 KB
Vibration, dust and heat (when dremelled) all can damage it. How short does it have to be? An extra nut on inside shortens it too.
I’m gonna a use a regular metal hand saw.
The knob is the problem, it ain’t deep enough.
But okay, I’m gonna try buy some nuts and see.
edit: no can do with nuts. See the spacing distance from frontpanel to knob?
    298.2 KB
    409.7 KB
All better now.. not perfect, but better than before.
I've put washers on the inside but the nut on the outside, between panel and knob is still too thick.
The question is, was the pot damaged during the process? 😅
Thanks for your inputs, guys!
    622.5 KB
    652.7 KB
Any guess why my MakeUpGain is affecting the meter?
With your red and green wire hooked up wrong (they need to be separate from the other part of the bypass switch), makeup-gain affecting the meter is your least concern. You need a little luck that your tantalum timing caps now fed with 0..+12VDC reverse voltage have survived this abuse...
I’ve now removed them to the other side and also removed the LED out if the circuit completely. Performs normal now.
That sounds serious with the cap. Is it gonna sound obvious if it’s broken or should I run some kind of a test/measurements?
Wonder how I should wire the LED now, for illumination..
I had the same issue and decided to use a L shaped aluminum profile attached to the bottom plate of the rack. The pots are bolted to the aluminium profile bracket through holes, and not to the face plate. This way you can place the bracket properly and the nuts will be behind the front plate not in front. It allows the knobs to be almost flush to the face plate and it offers some extra rigidity to the whole assembly with the profile/bracket going throughout the whole width of the enclosure.
That sounds like a great way of solving this. Thanks for the advice.
I would love to see how it looks.. if you have any photos or links, feel free to share them :)
I've done the built of the SSL, and before mount all the IC's I'm checking the voltages.
+15V and -15V are ok
+12V ok but I have -11.88V. This is normal?
I changed the 9L12 and I have -12.44V. So I think, that depends on the voltage tolerance.
Anyone can tell me if this voltages are correct? THAT2180.
With the THAT plugged I have -2.93V instead -8.93V.
    1.3 MB
