GSSL HELP THREAD!!!
Hello, I've been searching for days now and there is an option paralysis because there are too many diagrams floating about. Some are even diagrams of mistakes.
Can someone please help me with wire diagrams for main board+superside chain with power+bypass(compression) DPDT buttons.
My head hurts 🤣🙏
Can you show one of the diagrams you found that show what you want to do. Its better to move forward from something concrete, rather than have to both lay out your exact need, then how to do it.
Gustav
Gustav
Can I use this wiring and skip the turbo?
Do I still connect 15+ 0V 15-?
Can I use this diagram for the buttons below? I'm ok with make-up gain being on all the time.
  • Gssl - Wiring.pdf
    1.2 MB
  • PB1 - Make up engaged.pdf
    47.2 KB
Hi!
So, i powered again the GSSL with all the IC's in place. No burning, so for the moment all good... Except i don't have any sound coming out. I have a 1mA DC meter connected but not moving, of course 😊
Btw, i made shure to short the two traces between ON-COM and bypass, so the compressor should be on and active as I'm gonna fix it. Also I've short the HP filter as for the moment i just want to make it pass audio.
I'm using VCA THAT2181A and I remembered that when I was compiling the BOM the "%" resistors (marked green in the picture) were not on the list and, of course, not present on the pcb.
Also, upon inspection of the capacitors i saw that on the output section, the 100uf capacitors (marked red in the picture) are bi-polarized (There is a problem using bi-polarized capacitors there? I don't remember ordering it this way but...).
Now, I don't know what to do next, but maybe someone can point me to the right direction.
- I've checked again the +15V, -15V, +12V, -12V, all good 👍
- I should change the bi-polarized capacitors 100uf/25v? Needed or I can use them on?
- looking for "%" marked resistors- if needed for VCA THAT2181A- I've attached the picture
- other ways to make shure that i can finish this project...
Also I'm starting to write a list for checking errors as I'm reading this big thread regarding my situation. Some solutions here made my life easier! Maybe when I'll finish this project i can upload it here as a pdf or as a list so others can benefit also.
Thank you in advance!
    545.1 KB
Hi!
Hey, on page #431 you can find the needed info for VCA resistors. Just follow the diagram.
Or you can buy THAT 2180 and skip those resistors.
Hi!
So, i powered again the GSSL with all the IC's in place. No burning, so for the moment all good... Except i don't have any sound coming out....
After confirming all supply voltages (+/-15VDC and +/-12VDC, maybe optional +12VDC) are operating correctly, get the audio path working before fixing the maybe faulty sidechain. Easiest seems to be to power down, pull both audio VCAs and link each VCA-pin1 with VCA-pin8 by a piece of wire or biro. With powered gssl and audiosignal feeding the input, the same audiosignal now should show up at gssl-output (with flipped polarity because of missing audio VCAs). Case audio is now working, replace the probably faulty audio VCAs and try again. In case audiosignal is still not present at gssl output, double check step by step for audiosignal present at input of balanced line receiver NE5534 in between pins 2 and 3 and at output of NE5534-pin6 in respect to 0V reference voltage. Case not, fix your hookup of XLR-input, solder connections or replace the broken opamps. Next check is for audiosignal present at NE5532 pins 7 and 1, each in respect to 0V. All fine, fix your hoopup of XLR-output.
