earthsled
Hello DIY-ers!
I have decided to build a compressor pedal using the GSSL pcb set. I'm excited to try this variation, I think the project will be fun, educational, and great for bass! It looks like the GSSL components will fit a Hammond 1550G box with room for a small internal power transformer (Hammond 187C36). It's a big chassis for a pedal, but good enough for my experiment!
My first question is about how to modify the input and output sections to be unbalanced and proper impedance/level for instrument input and amp output. It would be great if this "mode" could be switchable so I could select line level mode vs. instrument/amp level mode.
The input section of the GSSL uses 5534 op-amps. Is there a way to adjust the resistance values around these ICs for unbalanced instrument level? Do I need to use different op-amps for this kind of input? Similarly, could I adjust resistance values around the 5532 op-amps in the output section to make the signal unbalanced and proper impedance/level for a bass/guitar amp? Or, maybe some kind of pad can be added to the output circuit for this?
My second question is about the GR meter. Ideally, I'd like to use an LED array or bar-graph for this pedal as the LEDs will be more durable than a traditional moving-coil meter. Can I use a VU-type LED meter with the GSSL pcb? Maybe something like this CEBEK VM-20 kit http://www.mcmelectronics.com/content/ProductData/Spec%20Sheets/28-5185.pdf ? Or, is it possible to design a simple 12-segment 1mA meter with LEDs?
Thanks in advance for your help!
Cheers!
Cheers!
