GSSL power supply question
jwhmca
USA
So it may seem crazy,
But I'm trying to run two GSSL's from one power supply... Separate REG's etc , but the same transformer... Should there be some kind of separation between the boards after the transformer? Will I get crosstalk by sharing the transformer?
abechap024 said:
If your using two separate rectifiers you should be fine.
I also think that´s o.k.,but-thinking about that for a while now-is it necessary to double (if used) the c-r-c-board also?
Thank you,
best,
Udo.
I thought using two CRC boards might be best... They don't seem like the are available right now... does anyone have a schematic?
I built 2 gssls in 1 case using a single vero board CRCRC filter supplying both boards. The CRC has a rectifier so it outputs a positive and a negative supply which I wired in to the gssl boards pos and neg regulator inputs.
