Gssl power supply
ok, very very informative !
I will just give it a try with the torodial transformer like its designed!
I just thought, the transformer will create more ripple, or bad noisy things.
I think it was just a miss-information on my side.
the GSSL needs +/-15V and +/-12V supplies. The 12's are derived from the 15's - they need to be CLEAN
extra filtering is a good idea when using switch-modes, they are nearly always noisy
if you are unsure what you are doing, you should really stick with the classic and tested version
/Jakob E.
Should the daughter board run on the AC power or should it be the converted DC power. Currently I am seeing AC power on the daughter board, just wanting to make sure everything is right, thanks!
