Comparison of JFETs for mic applications
I've always been curious about this method of biasing the 2SK660; it's from the Audio Technica AT8533 power module; so different from the way FETs are usually biased in microphones.
The PNP transistor acts in effect as a Zener Diode (or Vbe multiplier), which produces a fairly constant emitter voltage.
The emitter is supplied from a current source (CRD) from the centertap of the output transformer.
The 1k load for the Mic capsule FET comes from the PNP emitter. It seems to be a follower, with the Diode in the acting as "floating" powersupply of ~ 0.6V for the J-FET, that's DEEP in the triode region.
As the signal out of the J-Fet goes via a cap to the base of the PNP the PNP transistor in effect bootstrap's the 1k Resistor.
Overall capacitances are well cancelled, it's a fairly linear follower into a transformer.
It looks complex, but fundamentally it's simple.
I'm not surprised it sounds good, if we measure this circuit, I expect even order HD dominant with very low order of HD, plus likely a fair bit of pink noise.
Thor
Thor
Thnaks
Did look like a bit of a bootstrap to me. Wonder why this type of bias isn't seen more often.
This is the Shure version (don't know for what FET):
  • SM90:91.png
    1.4 MB
Most people get a headache looking at this.
The J-Fet operated at extremely low voltage.
There seem to be many thermally dependent voltages.
A lot goes against "received wisdom".
Peeps just "don't get it"!
Thor
"fast and bulbous
(Hey, do it again) I love that, I love those words
Fast and bulbous, that's right, the mascara snake
Fast and bulbous
Bulbous, also tapered (yeah but you gotta wait until I say it)
Also, a tin teardrop (oh, christ)
(Again, beginning)
Fast and bulbous, also a tin teardrop
Bulbous, also tapered, that's right
A squid eating dough in a Polyethylene bag
Is fast and bulbous, got me?"
Q115 Q103 (PNP) is the constant current source, there is implicit looped feedback from the follower (Sziklai circuit) emitter via the zener diode.
R115 (8.2k) with C110 acts as the "flying supply" for the J-Fet, with Q102 acting as the same follower as in the Audio Technica circuit.
The second follower is also switchable highpass and perhaps an overengineered part.
For a simple modern version with 21st century parts, use 2 X E102 CRD from pin 2/3 of XLR (2mA constant current), J-Fet and source resistor (say 10k for 500uA Idss) and BSS84 as follower and to bootstrap Cgd, coupling cap. Capsule to ground, J-Fet gate sits at ~5V.
As pin 2/3 with P48 will be at 41.2V, we can easily derive 36V bias Voltage for LDC Capsules. If using P68 (my "personal" standard) we get 56V Bias.
Marginally more components that the simplest possible circuit, but better performance all around, including noise.
Thor
Q115 (PNP) is the constant current source, there is implicit looped feedback from the follower (Sziklai circuit) emitter via the zener diode.
Thor
Did you mean Q105 (CCS)?
The bootstrapped JFET principle was discussed on that other microphone forum and inspired me to build something similar, with such a circuit on both the inverting and non-inverting outputs of the microphone. The circuit would have zero electrolytics, lending itself very well to miniaturization. Gain close to 0dB, and according to simulations very low distortion, extremely high SPL handling and low noise. Everything except the low noise came out as predicted. It could handle 7V RMS on the input at 0.1% THD. Just noisy as hell and I still don't understand why. Maybe I'll publish it here later on GroupDIY.
Jan
Theoretically good idea.
Excess noise from poor resistor choices? I had an SMD thick film accidentally in the tail of a folded cascode circuit where the input side was capable of < 0.5nV|/Hz and had 40mA/V transconductance.
Replacing with a generic (Yageo) thin-film resistor dropped noise a lot, going MELF got close to predicted results.
Thor
Q103... It was by my first coffee.
My brain and memory ain't what they used to be. Then again, they probably never were.
Thor
Ah, that's okay. Now it makes sense. After too few hours of sleep, before coffee and at my age, my eyes and mind still play tricks on me 😵‍💫
Thanks for your objective analyzes of electronic circuits, it's a pleasure to follow your posts. And your humor is comforting 😁Cheers!🍻
Correct, the datasheet shows the curves for 250uA Idss @ 10V. They obviously shift with Idss which is a bit variable, especially in older J-Fets.
The difference is ~ 50%.
My computer and office/lab is in boxes, until I unpack and set up, no model.
I pontificate slightly on this in FETbias.doc
I'll wait on your model. In the meantime, I'm trying out some easy stuff with the LTspice model. It's of course important that we are 'using' the same model.
It can plot against any axis format you elect to use. The stuff you dis.iss as "unnecessary bells and whistles".
Please use this "bell & whistle"; plotting noise spectral density against log frequency as it is fundamental to our comparison.
Can you leave Zeph out until.he starts using nbers that actually make sense and are within reasonable variations of reality?
I have zero confidence in what is in this doc.
Sigh! It may have escaped your notice that I did the measurements in Zephyr.doc ... and I used my own "bell & whistle" to show the noise spectrum. The exact details are in the document. As this is a constant relative bandwidth display, the details are important.
I'm not sure what numbers you are complaining about. I think you are querying the absolute level.
Alas, I don't have an absolute level calibration and I make this clear on pages 1, 7 & 10. The only number I have for the ECM 8000 is a cryptic "-60dB" number on the box. 2025 ECM 8000s have a different "70dB" cryptic number.
Jochen Schulze has 15mV/Pa while you claim 8mV/Pa
I'm not surprised that these 4 numbers are very different as I'm aware of at least 3 very different circuits for ECM8000. At least 2 of them are guilty of the heinous crime of taking power from only side of a P48 line :eek: .. but I forgive them cos there are a couple of big name Germans who are also perpetrators and SimpleP48 of course :)
I also explain my crude overload test and say "Can’t tell much from this VERY crude test except that overload probably very high" on page 2
But what have you got against the noise curves on page 10 ?
Absolute levels have no bearing on these curves which were all taken with the same setting on the preamp. So the info is all relative.
PLEASE post the circuits you want me to simulate as "SimpleP48" and "SimpleP48RCA", with all values according to the capsule and J-Fet as mentinoned.
I'm doing my best in between my beach bum activities. Dis LTspice sim stuff is new to me but I'm learning. I hope to have both circuits ready with the correct models by the time you have unpacked ... and hope to be also ready to tweak them with your model when available.
So far you have been endlessly prevaricating and sandbagging and moving goalposts, after first a lot of big gob trash talking.
There appears to be a lot of gob trash talking but I'm not sure I'm the generator :(
I already conceded that the theoretical electronic noise limit of the Schoeps derived circuit will be as much as 10dB greater, simply due to resistor noise.
I missed that :eek: Where did you post this?
BTW for the record, my claim is that Zephyr's Schoeps variant is 10dB quieter than yours with a capsule similar to his ... and SimpleP48 is perhaps a dB quieter than that.
When your TINA sims prove or disprove this claim, will you enlighten us as to why you think this the case?
The tradeoff is lower HD (dramatically so) and the ability to handle high SPL's, which is what I emphasised in my design.
If you want to use a modern electronic (not transformer) input mic pre (build into a USB soundcard) and you are not interested in low distortion at typical recording levels for music, but only in low noise, for very low sound levels.
But I AM interested in high SPLs & low distortion. That's the reason for SimpleP48RCA ... which BTW is on page 12 of SimpleP48.pdf ... as one of the 2 recommended variants. So I'm not sure it counts as "moving goalposts"
I think I've mostly avoided "wi**y wan*ing" in this post :)
With some luck we might all get something useful out of this if Thor & I stick to refining our models so the sims represent 'real life'
