Had some questions about this 'mod' and i will try to make a more readable schem for it, i allways tend to do this kind of stuff out of my mind and i'm baaad when it come to drawing stuff.
It is indeed possible and it works great i must say.
But sometimes you want the SSL to be more like a pumping compressor and then the GSSL mode is a must with sidechain filtering, if you want nice, smooth but pumping compression you want turbo.
I was also thinking of another mod some time ago to make it even pump more, kinda like a reverse thrust circuit, boosting bass, cutting mid/high so that it just reacts to low end.
So a bit like an external sidechain but the internal.
Will that be interresting? :roll:
[quote author="ask"]Nice! :thumb: I knew it was possible, would like to do the same trick. I can't really follow your drawing though, any chance of an "officaial" schem with added changes? Please? :wink: :sam:
[quote author="dagoose"]I just modded my second GSSL with another turbo board and made this one switchable with just one hp filter board.
This hp filter board is just 4x hp freq and a external out so a 6 pos switch.
I never used the external sidechain so that position is now the turbo position
To make it work i added a relay based system, otherwise it wasn't possible.
When i switch to the EXT position the relay gets 12v and switches to turbo. :green:
When in off it's just like a no modded SSL and then i still have 4 positions with hipass in regular mode as well.
I made a simple drawing the way i connected things.
The rest is connected as it should be according to the turbo drawings.
This way you save one sidechainbaord in case you want to use it anyway (in turbo mode you don't really need it) and still have GSSL mode with sidechain.
If you use a 2 deck switch you can use pos 11 or what ever on the second deck to power the turbo mode relay.
[/quote][/quote]
