I've read somewhere from
Script and
Harpo that if you're only using one of the inputs (L or R) because you're using two boards, then you should change the 20K resistors to 10K's on the SSC's input (because the board is made to be used with two inputs, L + R, so just 1 single board).
But when using two boards, and each board only gets a single signal (L or R), either change those 20K's to 10K's or keep the 20K's and add signal to both inputs (L & R). Since I populated both boards to completion, with the exception of a Relay on the Right board, I don't wanna bother to change the resistors to 10K's, so I'm connecting both L & R from SSC to main-PCB's output.
But I can be totally wrong here, I have no idea what I’m doing. This is just research I’ve gathered. No one with experience has confirmed/denied my diagram sketch.
The Don's diagram isn't working properly for many users, or at least is causing problems, especially the + & - on button LED's. I don't know why his diagram is using power for button's LED from main-PCB when you have the option to connect any LED to your SSC.. it seems complicated to me. Or maybe it's not based on
Gustav’s SSC-boards.
I wired my button signal to the corner of Control-PCB (power on LED) and that works. The other button LED im gonna connect to SSC. His diagram isn't complete, no! So I don't wanna depend on that.
The
RET (return) is the signal going
out of the SSC board. The L & R are inputs, the RET is output.
But again, I’m not a 100% sure of this. That’s why I haven’t started yet.
I’m still waiting for someone experienced to say yay or nay.
The info can be found here on page 6, 9 & 12 of:
GSSL ass-on help thread,
here and
here.
Also from
tomcat
