RogerAF
I installed a recording studio in a new house for a client. He bought a balancing transformer and mounted it on the wall of the garage which was below the control room. It was installed by a "licensed electrician" (insurance reasons) and the center tap went to the ground at the meter. That thing buzzed so loud you heard it throughout the house. Not electrical buzz, but actual physical vibration transferred into the structure. I told my client that it needed to be mounted outside on a separate concrete base, in a weatherproof housing. But I don't think that's your problem.
When I guilt my studio I took a 240V feed from the meter and ran it to a a pair of 20A Power Line Noise Filters, added MOVs for surge protection. I used 3-wire cable for each circuit and added 6' copper earth ground rods 10' apart--one for the lighting circuit and the other for the studio outlets. All outlets were isolated ground types. All the wires were in rigid conduit that was grounded at the breaker box. Only the conduit was grounded at the breaker box. All outlets and lighting grounds went to the earth-rods.
That worked beautifully! My dad's shop was next to the studio and he could run any power tool or table saw and there was no noise in my monitors or in the guitar amps.
IMHO the whole idea of "Balanced AC Power" is a kind of audiophool-ishness. Especially when it comes to guitar amps. Our amps in the USA are designed to have a hot leg, a neutral leg, and a ground leg. The ground leg connects to chassis ground and insures protection from electrical malfunctions (including electrocution). The guitar cable's shield is connected to chassis ground and thus to mains and meter (earth) ground. If it's a tube amp, chances are that the -V side (after the rectifier) is also connected to chassis ground. The neutral wire is only connected ground at the meter. It then "floats" throughout the building. The little Power Line Noise Filters I use are rated at 120/240VAC @ 20A. They have a neutral leg, a hot leg, and a ground/case leg. They used to be $5 each, but now I have to go to ebay and they run about $15.
Your balanced power transformer should have a center tapped secondary that IS connected to earth ground at least at the meter. Or you can install another 6' copper rod into the earth in your studio and hook all your studio outlets to it. That goes then connects to the center tap of the transformer secondary and NOT to the meter's earth ground.
To me, it sounds like a grounding issue. And radio pickup also indicates that. The whole idea of a balanced supply of 120VAC means that each leg is at 60VAC when measured to ground. And ground voltages can change from one end of a building to another end. The military specs grounding rods at 10' centers throughout all warehouses. All outlets connect to them. They all connect to each other, and to the earth at the meter. So make sure your transformer has a center-tap on the secondary, and that the ct is grounded to the earth. (Tech Tip 1: Check that any screws or nuts that make connections to your transformer and to your outlets are all tight. And that you use crimp connectors on the wire ends where they connect to the outlet. Do not just wrap the wire around a screw.) (Tech tip 2: Get an outlet strip that has Power Line Noise Filtering--not just Surge Protection--try that on an outlet. If you have to, run an extension cord to an outlet NOT connected to your balancing transformer. What happens then?)
On a side note: I once did a session at a studio with my Les Paul and small Marshall. Things were going along fine (I thought) I had my headphones on. But when I took them off, I could hear the playback coming from my amp. I called one of the engineers in and we eventually discovered that my headphone mix was somehow getting into my guitar and thus to the amp. His solution? He soldered a wire to a copper penny which I put against my skin under my belt. The other end was soldered to the cover of my guitar cord plug. That fixed things, but no one ever figured out how that problem even existed in the first place. It only happened when the headphones were on my ears or down around my neck. Go figure!
