I hope you guys don't mind guitar amp stuff here too much. I thought I'd be best asking here as there is no bullshit, and a lot of clever people.
Anyway, I have a Wem Dominator 15W valve amp which I use as my bedroom amp. I can't play it loud which is a shame because it stays fairly clean even at neighbour-annoying levels.
So, I am considering modding it to get some preamp distortion of the Marshall flavour. I have a DSL and have used JMP/JCM800 master volumes which I like.
Funnily enough, the amp is very similar to the Marshall 18W since Wem sold the basic circuit design to Marshall. I think Marshall probably modded the design to make it rock though...
The Wem schematic is here:
http://www.vintagehofner.co.uk/britamps/watkins/schematics/dommk3.html
and you can see the similarity it has to the Marshall schematic here:
http://elektro.cmhnet.org/~graydon/photos/musicstuff/marshall/marshall18wattrev4.pdf
So, for starters, I suppose I could just mod one channel of my Wem to that of the Marshall 18W preamp and see how it goes, but even then, it doesn't look like I'm not going to have much distortion at low volumes. I'm not sure though - I haven't tried one, but the lack of a preamp gain control doesn't suggest it would provide much.
As an alternative, I was thinking of changing part of the preamp to that of a early JCM800 as seen here:
http://www.tone-lizard.com/images/JCM800_pre.gif
In this case, I would maybe copy the first two stages and feed what is connecting to the third triode in the schematic (to the right of #3) into the master volume pot of the original Wem schematic.
I'm not sure if this suggestion is complete madness. For starters, I don't know if those two triode stages which I would have copied would provide much distortion, and also I am not very savvy with valves and their corresponding input and output impedances when in circuit. Also, I only have space for three knobs and a bright switch which I suppose means preamp gain, master volume and "tone".
Any suggestions would be appreciated. All I want is a good Marshall-style distorted sound - I appreciate that the output section will still remain (it's good anyway). Also, since the amp has two channels, I can keep purists happy by maintaining an original channel.
Roddy
Roddy
