SSLtech
...But it IS used as a mastering limiter. -By several mastering engineers.
I have the impression that people may be reading things that they don't fully comprehend, and then asking how things can be "changed" to suit some sort of misunderstood model that they have formed in their mind.
It's an excellent limiter.. -The signal path is simple. The sidechain is quite brilliantly engineered. There are well-established variation mods such as sidechain filters, twin-sidechains ("turbo" add-on), metering/display options (LED bar/milliameter/VU 'down-from-zero') etc.
If you absolutely "MUST" have infinite ratio, build it as shown, but adjust the value of a resistor in the sidechain (use a trim pot to fine-tune, and do the same for one resistor in the turbo sidechain...measure the output of each channel individually and singly if using a turbo, and both channels together if building an unmodified GSSL) and you'll have an infinite ratio in place of 10:1. (in fact there's little obvious difference in operation to the user)
the gyraf website is running at crawl-speed, so I can't tell you the resistance value right now, but I can probably do so later on...
