Samuel Groner
It's impossible to give a general answer to the question whether to terminate vintage gear with 600 ohm or not--in many cases, high frequency response will be smoother with 600 ohm termination, but distortion and low-frequency response may suffer. Look at the Great River MP-2NV user guide, IIRC there is a section on this.I was under the impression that these old circuits performed best when terminated with 600 ohms, i.e. if the 2503 output transformer is connected to a 10k input, then the transformer should ideally have 600 ohm strapped across it's secondary. If outputing into a 600 ohm input, then the termination is taken care of. Is I wrong, or is I right?
A compromise might be a zobel network load, e.g. 3.3 nF in series with 600 ohm--this should keep the HF response clean but decreases distortion in the audio range. Some experimentation with the optimum capacity value is needed though.
Not that the above consideration only apply to transformer balanced outputs. For other output stages less loading is better in about any circumstance.
Samuel
