grantlack said:any ballpark current draw numbers from early builders on these and/or the 312 build parameters? this will obviously fluctuate a bit, but i'm trying to weigh my options for power supply needs.
grantlack said:i'm assuming it's 1:2 like the jensen, but you know what they say about assumptions. anybody have those handy?
mitsos said:In the case of the M1, I tested with an Altran 3982. It's a 1+1:4 input trafo (wired it as 1:2), smaller than the JT16 I think.
pablobolche said:I am building this M1 build and new in diy and electronics and have read some of the caps specs and descriptions but a pratical Q, on selecting the 91pF feedback cap for the 22k rev log pot. What kind of cap is good for this.... polyester, ceramic, tantalum,low ESR, high ripple current.
Is there a "this kinda cap is good for a feedback loop / audio path / power line rule you can follow? Other than reading all posts regarding caps of course.
thanks for any help
They work in conjunction to eliminate DC offset on the 990 output when not using a cap between opamp and the CMOQ. You first adjust the bias trimmer so that you get very little difference in DC between min and max gains (measure between output of opamp and ground with servo out of circuit), once that is within the tightest tolerance your DMM allows, connect the servo and watch it go to zero. There is a detailed description of the procedure in John Hardy's 990 pdf.Soeren_DK said:I have the Mitsos pcb laying around and thought combine them with parts from my old API312 project.
So I have some question.
- What does DC servo and Bias do? and can I leave them out?
I have a single-sided one that you can etch if you want. I tried posting it before but the links always disappeared. Let me know if you want it, I can email the files to you. On the other hand, the 4th rail is for the LEDs, you could jumper that to the +V and G and use the positive rail.- What about all the voltages on the board? anybody designed a power supply?
Which Altran input did you get? The 990 one (1+1:4) or the 312 one (model 3402-2, 1+1:8). If the former, you can use it in 1:2 (primaries in series) with about 6K as a load. I haven't done any tests for zobels on this trafo because I moved recently and the place is still a mess.- I'm using Altran from the groupbuy, what resistor should I use?
With a 990 opamp? You should be able to run it as in the 312 (1:2 with an Aux output, will give you +6dB of gain), but test it, as it may work better as 600:600, with a pair of windings in series on each side. Check the PDF for the CMOQ and wire it like "Test Circuit 4" except leave out the 604R on the output side.- Any corrections when using Cinamag CMOQ-2S as the output tranni?
Which Altran input did you get? The 990 one (1+1:4) or the 312 one (model 3402-2, 1+1:Cool. If the former, you can use it in 1:2 (primaries in series) with about 6K as a load. I haven't done any tests for zobels on this trafo because I moved recently and the place is still a mess.
http://cinemag.biz/output/CMOQ-2.pdf
Cleanest way to configure the windings this way: Connect Red wire to pad G and Orange to pad Y. Then Blue to pad GY and Violet to Pad V and you place a jumper between the 2 pads for the Aux output Molex.
THEN:
Brown goes to the pad marked "BR",
Yellow goes to the pad marked "R",
Green to the pad marked "O"
Gray to pad marked "BL"
Unless I mixed up the colors, that should work!
good luck!
