back side of board, pots have a different look to the solder, means they were attached after the board came out of the wave tank,
there are about 3,641 linear pots listed in the DigiKey pages,
got to get the right size, right resistance, right shaft dia and length, got to get the split shaft with splines, side adjust, top adjust, rear adjust, detent at 12 o'clock, time consuming,
https://www.bourns.com/data/global/pdfs/PDB18.pdf
so we order the PDB181-K220K104B from DigiKey for $1.26 ea, $2.86 shipping,
then you have to find a knob because the old one is still attached to the broken pot shaft, probably sitting in an ally behind Studio 54 somewhere or maybe CBGB's,
so you scour the net for another marathon session, sorting thru 10,000 control knobs,
close, but no match, BassTalk forum says go to radio shack, :'(
so you call all the Hartke authorized service centers and they tell you to call Hartke, :'(
so you call Hartke Service in NY and the guy says he will send one out for free,
1-631-784-220
you know something.....
if this was a pre CBS Fender, i would be done by now, ;D
