My guess is you may need fan cooling.
I installed the power supply on top of x2 aluminium sheets of 2mm (couldn't find a 5mm plate at the metal shop junk box..) and added some thermal paste for good heat transfer.
I originally had bought and tried a 600Watt SE series Meanwell power supply, but this unit had really impressive fan noise! it was WAY too noisy and so i decided to change it and got an UHP series, this model uses no fan but they need to dissipate the heat on the chassis or an aluminium plate as advised on the UHP series documentation.
You can see on the photos the placement of the IEC connector was originally very close to the input connectors due to the quite big 600W PS (not very good especially with vulnerable unballanced inputs!) Paradoxially, the new power supply can deliver more power (750W) and is smaller ! so i moved the connector away from the inputs, and put a little aluminium plate to close the big ugly hole...
All my fault as I had started the chassis work before testing the power supply, lesson learned !
