ksor
I need distribution to 4 headphones - just like this Powerplay HA400 - but DIY !
Can you recommend some schematic ?
Rob Flinn said:There's a reason that there aren't a lot of projects for headphone distribution systems, & that is because you can buy the HA400 for £22 UK which means it's hardly worth the effort to build one. If you add up the parts cost & your labour it would actually be a lot more expensive for you to DIY it.
That said, don't let what I've said put you off building your own headphone distribution if you really want to do it !
RuudNL said:I have used this in the past: http://www.groupdiy.com/index.php?topic=47920.msg604187#msg604187
(I used 1N4148 instead of the LED's)
Rob Flinn said:The led's keep the transistors biased correctly. The reason red ones are specified is because the have the needed voltage drop across them, which would be different if you used yellow or green etc.
RuudNL said:1 - The schematic works fine as it is. You can (as I did) use 1N4148 diodes instead of the LED's.
2 - I used small heatsinks in my heaphone amplifier, but the transistors never were hot or even lukewarm.
3 - I think 10 VA is enough for 8 headphones. Suppose the efficiency is 50%, that will give 5 VA audio.
5 / 8 = 625 mW audio per headphone. That will blow your ears off!!
It's planned to mount in my DIY rack placed against a wall but with wheels so I can drive it out on the floor and access the rear of all the units (all just for hobby !)sodderboy said:You mentioned "panel" a few times- are you building these to mount on a wall panel or in a rack case? I mention it because you can lower your parts count, board size, and time factor with something like the TDA7268, a stereo IC power amp, or make a single amp based on a larger monolithic and use resistors/pots to distribute. That is if there is only one source always like the traditional distributed cue system.
Mike
mulletchuck said:Is that 4 headphones in a 19" rack space? This presonus HP4 is tiny, like 5" across and VERY loud...
