To come back to the original question. I just did a test, and the headphone effect occurs with a U 87 Ai in all three directional characteristics, including omni. So it is not dependent on the proximity effect. That's what I expected, but I still wanted to do a test as - sometimes - the unexpected happens, and if it does, there's something to be learned. But in this case, it's just what most people around here expected. Case closed.
For the record, I used analog monitoring (via a Universal Audio DCS) and a semi-open AKG K 240 DF, which is what I tend to use for vocals.
I do think that latency is a big issue. Not in terms of a time delay (which is barely perceptable at 1-3 ms) but in terms of comb filtering. A sure sign of latency problems is when you can't decide which position of the polarity switch puts your voice in phase with the acoustic path.
Although I have to say, digital systems are getting better. Some newer audio interfaces' internal (digital) monitoring is so fast, that it almost sounds like analog. I'm guessing 1 ms digital latency is acceptable. But as soon as you monitor through your DAW, I don't think that's attainable.
