James HE
a long long time since I've visited here!
I record myself a lot, and I'm brainstorming ideas for a little mixer / headphone amp to make my life a little easier.
I think what I want is a mixer with 2 stereo inputs. Input 1 would have a switchable MS matrix. Input 2 would be switchable to mono. Then, of course a headphone amp after that.
I think I can cobble together parts of different schematics to build it (hopefully)
for the MS matrix i will likely use this http://www.groupdiy.com/index.php?topic=21795&highlight=matrix
for the headphone amp something like...
http://headwize.com/projects/showfile.php?file=cmoy2_prj.htm
and hopefully muddle through the switching and summing. I'm very much a newb. I got into a little DIY about a year ago, studied and read a lot, but never successfully built anything. So any guidance I can get will be most helpful. I wish I had more specific questions at this point, but I'm just digging back in.
I will be coming out of the balanced / unbalanced outputs of my soundcard, so unbalanced input should be fine. (will also decrease the cabling I need to send to the thing) Should I use an opamp buffer on the inputs at all in this case?
I'd love to just use stuff I have on hand for this. I have some INA134 to use for the MS matrix and some ne5532 that I'd like to use for the rest. Is there a more suitable circuit for the headphone amp since I will be using 5532's?
Should I use active summing here? Or could I passively sum the inputs and let the headphone amp provide makeup gain?
When I get a preliminary scem I'm comfortable with enough to post I will.
