In the course of clearing out some of my moms personal effects , I found her hearing aids , one had developed a problem way back and she had been intending to purchase a new pair , sadly she passed away before taking delivery of a new set which were costing around 2500 euros .
Six months ago I just happened to find a single almost indentical working hearing aid on a footpath a short distance from my home , today I took a closer look at the broken unit , the wire connection to the driver transducer (ear piece) was intermittant , luckily the one I found on the path was also the right hand side of a pair . It took about 5 minutes to gently prise open the housing , pop out the pcb/mic assembly then plug out the old defective transducer and replace it with the other working part . Simple job to do , a little fiddly due to the small size but still a very easy fix . Anyway just a word of warning to any of our more senior contributors, theres a couple of really simple faults common to most hearing aids that cause intermittancy , one is the ocassional need to re tension the battery contact terminals , a small screw driver is all thats required to give them a little more spring in the right direction and make proper contact again , the other is as mentioned damage to the cable leading to the ear piece . Anyway if your having trouble with your listening devices , do not allow the sales person to fob you off so easily and take an extra couple of grand off you for his trouble selling you the newest all singing all dancing 'latest' improved functionality model . Demonstrate the fault to the saleman and demand the spare part from him or if thats not possible you may be able to pick up a single working unit from someone who lost one of the pair , these do come up very cheap on ebay . Anyway just thinking about some of our contributors stateside who might be already put to the pin of their collar with medical expences , dont not get taken to the cleaners by some salesman with a gentle bedside manner but in reality gets a huge commission on what he sells .
I may actually pay a visit to the local hearing aid shop next week to sus out the possibility of some work repairing stuff ,although I'm pretty sure he's not going to like the prospect of loosing his cut on new sales much . I'd would also like to get my hands on the USB programming cable/software just to see how it works .
