lassoharp said:I thought I recognized a couple of those L tap values as Carnhills. The max cut & boost values look plenty ample. The MEQ 5 clone I just did is only designed for 10db of boost/cut and it covers most common situations, so yours is a step up from that and only a db or 2 here and there away from the EQP1A.
Is this the design that's going into your tube mixer?
The reason I built the rack is that I have two prospective clients, one of whom wants a tube mixer with the modified Pultec EQ, and the other who wants it with a tube based Helios Type 69 EQ. So, thinking I could kill two birds with one stone, I decided to build a rack mounted demo unit of both so they could play with them and I can also use it to demo EQ possibilities to other prospective clients. The rack unit goes in the post to client number one this week.
Of the two EQs, and having played with them quite a bit myself, I think I prefer the simpler Helios. The HF is great for adding clarity. The mid peak/trough is good for emphasis and the extra frequency at 16KHhz for air. The bass cut, though simple, is not shelving so it just goes on cutting forever and the bass boost being inductive based has a nice ring to it. I am not surprised the Helios EQ is considered very musical.
