Help! 1272 as Mic Pre with LO2567 and T1310 on Output
Whoops
GDIY Supporter
Portugal
Im finishing a 1272 using the Hot Rod pcb.
The transformer I have for the Output is a LO2567 (un-gapped) instead of the common LO1166 (gapped).
I have the T1310 inductor.
Ive read that you can connect the T1310 and the LO2567 to the output of the BA283 instead of the LO1166, I just don't know whats the correct way of doing so.
Can please someone help me on how to connect this?
Thank you so much
Regards
Using the BA283AM schematic: Connect T1310 to B and M. Connect LO2567 between F and J. J (and A) should still connect to B- (0V). Wire LO2567 like LO1166 (series-series)
Good luck!
M.
Good luck!
M.
Thank you so much for your knowledge and help Martin.
I did redrawn the schematic for these connections, so it could be verified if I understood well and also for others fellow diy'rs use in the future.
Please let me know if I got
Thank You
Whoops said:
Good luck!
M.
Thank You
Do I need a Blocking Cap Between F and the LO2567?
Please :
what type of cap is that indicated in the attached image ?
many thanks in advance
r
r2d2 said:
Please :
r
Poly-Estere I don't know what it is, do you mean Polyester?
That cap can be any type Ceramic or Film Capacitor (Polyester, Polysterene,Polypropylene, etc), any will do.
Whoops said:
C7 is the dc blocking cap
I checked that and read that in this configuration C7 sould be changed for 220uf instead of 80/100uf in order to maintain the Low Frequency response.
Does that make sense?
thanks
thanks
yes you are right : polyester cap
(fast typing error , sorry)
r
