Hi everybody,
I'm in very need of help. I have this phaser on my workbench and I can't get it to working right.
For starters, here is the webpage where I've taken the project from:
http://topopiccione.atspace.com/PJ05EHBadStone.html
schematic:
http://topopiccione.atspace.com/pjimages/EHBadStone.sch.gif
layout:
http://topopiccione.atspace.com/pjimages/EHBadStone.lay.gif
alternative schematic:
http://www.digitaldestruct.com/BadStoneSchematic.bmp
I've used the components specified in the project: for the CD4049 I've used the unbuffered version (don't know if the buffered version would be better..??), for the opamps I used TL072s and for the LFO the LM324 and for the transistor I've used BC549C (turned around 180 to match the pinout).
The first error I did, and it took me a while to figure out, was a short between ground and Vref. After I noticed it, I replaced all the ICs to be sure and when fired up the pedal started phasing.
However, I have a problem around the LFO I guess, because it actually isn't a sine wave sweep but more of a stepped one. Here you can listen to a sound sample to have a clearer idea:
http://soundcloud.com/mxxp_labs/bad-stone-lfo-sample
Another strange thing, when I switch from Manual mode (the LFO is out of the circuit and the phasing sweep is determined by the manual pot or expression pedal) back to Auto mode, the LFO stops working definitely and I have to power cycle the pedal to get it working again.
I've already checked all the connections and components values, replaced all the semiconductors with fresh ones and the polarized caps and diodes too, but I can't figure out what's wrong in the circuit.
As I'm totally stuck with it I really hope for your help. Any additional information or measurements I can provide, just ask.
Thanks in advance
schematic:
layout:
Thanks in advance
