Hi everyone, hope you all are doing well.
I have an Electro-Voice AC one active crossover, which employs relays at each audio output to prevent power-on thumping in speakers. During normal operation I power the crossover on and you can hear the relays switching correctly and the unit works with no issue. Now after about ~10 minutes the relays will click and there is no output, though the unit is still recieving power and input signal. You can see the signal indicator lights still operating, though the outputs are muted.
Now I originally thought the issue might be with one of these relays which are placed just before the outputs , but all the channels would stop working so I figured that wasnt the problem since its rare that all 5 relays would be malfunctioning (Do relays even go bad?)
After cracking the case on the unit a strong smell of burning plastic/components hit me and after searching for the culprit I saw the power tranaformer was smoldered on the corner (see first picture).
I checked all fuses, they are the correct values as well as the input selected for 100-120VAC (Im in USA)
Any idea what the cause of this might be? Im assuming the relays are getting an inconsistent voltage from the PS after the power transformer gets really hot and they mute the outputs. But what would cause the power trans to get this hot?
Any input is appreciated. Thanks
