HELP diagnosing guitar amp Bass pot please
sonolink
London-Madrid
Hi guys,
A friend asked me if I couild fix his Hughes & Kettner Staesman Quad EL84. The amp would loose sound after a few minutes of playing. I replaced the tubes and the amp is now working ok, I've had it on for more than an hour and it sounds fine BUT the Bass knob doesn't seem to work or do much. So I wrote to H&K and they sent me the attached service manual with the preamp schem but TBH I'm a bit lost here...
Can someone please help me pointing me in the right direction towards what/where to look for?
Thanks in advance
Sono
  • Quad-EL84.pdf
    2.5 MB
Bass potentiometer seems to be dual section 500K log on schematic.
Not uncommon to see 16mm pots fail on guitar amps, particularly when the pots are PCB mounted, the carbon tracks can easily crack with the kind of abuse that combo amps have to endure during transport.
You might be able to check the pot is varying resistance while in circuit, if there is some resistance change then you probably should look elsewhere.
It could be it's loosing bass before the tonestack, so the bass control doesn't have much to begin with. Check frequency response on the output of the preamp tubes
Thanks for your help Beatnik. I'll check the pot resistance.
Excuse my ignorance, how can I do that?
Sono
Perhaps easier to check the pot with VOM using ohms scale. Should read roughly marked resistance between the potentiometer's two outer leads. The wiper (the middle pot lead) will read varying resistance between the two outer leads as it is turned.
Do this with power turned off... be careful.
check outside pins to the center pin, if infinite ohms from 1 leg to the center then the pot is bad.
thanks for the schemo!
sometimes bass controls are subtle, like on some Marshall amps, maybe tune the guitar E string down and see if the bass control works down there.
Thanks for all the input guys!
I'll try all those suggestions and report back :)
Signal generator and oscilloscope
Ok, so that would be sending a 1kHz sine wave into the amp input and connect the scope across GND and the preamp output tube terminal BUT I can't find that anywhere (I'm probably blind on this hehe), actually I have the impression that this amp's preamp doesn't have any tube at all!! I'm probably mistaken but the two ECC83s seem to serve a different purpose (reverb, FX loop maybe?). Of course I might be completely wrong on this one, this circuit looks way more complex than a Plexi or an AB763!
If I'm right on this then maybe I should connect the scope somewhere at the output of the preamp (TP13)?
Sono
The schematics are labelled pretty clearly: page 26 of the document you linked has "Preamp" in the title box and is all op-amp, page 27 of the document has "Power Amp" in the title box and has the tubes. Unfortunately, the page labeled "Power Amp" also has the ECC83 pre-amp tubes, which makes it unnecessarily confusing.
It appears that the "Preamp" page has all the solid state circuitry, then the "Send PRE-TUBE" signal gets sent through a connector to the tube section where it goes through the preamp tubes, then comes back to the solid state circuitry through the "Ret PRE-TUBE" signal to the tone controls.
So you can check Send PRE-TUBE to verify that the solid state circuitry has all the low frequencies you would expect, then check Ret PRE-TUBE to make sure the tube preamp section did not lose too much of the bass along the way to the tone stack.
Op-amp U8B buffers the output of the tone stack, so you can compare the input to the tone stack and the output of U8B to see if the tone controls operate like you would expect.
Sono
I would suggest a lower frequency test tone, like 100Hz if you are looking for issues with the bass EQ.
I would also suggest that you do an amplitude sweep through the whole device and see if it's lacking in low-end overall. If so, that could point to an off-value electrolytic capacitor in the signal path. If the amp gets warm inside and is a few years old, it could be that the e-caps are failing.
IF, you see rolled off response from the whole amp, you can then break up the circuit using the Send and return jacks to try and isolate where the bad cap(s) may be. Do a sweep from the Input to the Send, and one from the Return to the Output.
Hehe I wish the schematic was so neat and clear as your indications mate! ;)
Thanks a lot for the clarification and suggestions.
Of course! I wasn't thinking when I said 1kHz...
Thanks again for all the useful tips dear friends. I will follow your indicatrions and report back :)
Sono
So the sound would drop out intermittently? And replacing the power tubes just fixed that? Are we talking it would drop out for a split second, or the amp would just go silent after a while?
Hi Alva,
It would go silent after a while. Probably some bad power tube that would stop working after heating up for a bit.
Sono
Hi Alva,
Sono
I've never seen something like this happen. And if it did, you should notice B+ increase as the power tube stopped drawing current. I have seen bad power tubes, make periodic noises or the sound would drop out for a second and return. You should double check the soldering connections on your heaters.
TBH, although I'm not a professional EE I've been fixing and building amps for more than a decade now (I'm still a complete ignorant though), and I've seen pretty much ANYTHING happen to an amp with bad tubes. From all kinds of noises, stuttering, popping fuses, low volume and a huge etc, so I'm not surprised at all that after a while the amp would go dead silent...
I'll check the heater connections but the inside of the amp looks quite healthy and clean. Thanks for the advice anyway :)
Sono
I would agree with Alva that a faulty power tube is unlikely to lead to intermittent total loss of volume, as the other or others would still be in circuit.
I have seen as suggested loss of heaters do this, you could maybe just see this visually when it happens.
Also loss of Screen grid voltage to both tubes would mute them, which is a power supply or PCB issue common to all output tubes.
Less common is loss of ground to power tube cathodes, also muting all tubes, but I can't remember many instances of this happening at all.
Incidentally, when this happens due to a loss of heaters, you will notice the sound fades out and back in, rather than abruptly disappearing and/or rapidly jumping between sound/no sound.
That's a bit of a giveaway really. If it is abrupt or crackling it is not the heaters.
Dirty tube sockets, or sockets that aren't making contact with the tube pins can cause this. I agree with Noisy, I would double check the screen grids. I've seen resistors do weird things when they start to fail, but haven't completely failed and this could be one of them.
It is always good practice as a tech, to hunt down the root cause of a particular issue. Just replacing parts, even tubes, can risk the problem returning, and costing the customer time and money.
