Help finding replacement / duplicating bias transformer
bjoneson
Oakland, IA
Background... working on getting a Scully 284B-8, 1" 8 track machine up and running. The electronics consist of 4, 4U modules, each of which contains 2 channels worth of electronics. Additionally... the first module also contains the master bias oscillator, and each of the 3 other modules contain a bias amplifier.
My conundrum is I have only 2 of the bias amplifier cards, and need a 3rd. They're virtually unobtanium, so I've resigned to etching / reproducing one. The circuit and layout is trivial, and I can source all the components I need, except for the transformer.
I've attached a schematic of the bias amplifier circuit, as well as a picture of the transformer from one of the cards I have, I'm attempting to duplicate.
In the schematic, it appears to be a simple step down transformer (shows 40V P-P on the primary, 5V P-P on secondary). The 160KHz bias signal is fed from the master bias oscillator to this amplifier card via P103(3) on the schematic.
I assume based on the voltages listed, it's an 8:1 turns ratio?
I'm thinking of potentially just winding my own, if I can't find a suitable drop in using the EPCOS stuff from TDK, but I have absolutely no idea where to start in terms of specs, what size core, what gauge magnet wire, etc...
Any help is greatly appreciated!
Many thanks,
Bob
    218.5 KB
Well, but it has a significant capacitor across a winding.
Smells like a tuned circuit.
Then again, if pin 3 drive is a low-Z source, 1K resistance feeding 0.001uFd resonant at 160KHz suggests a Q very near unity. Hardly a sharp filter.
I'm wondering why it even has a transformer. Ground isolation? No, because pins E1 and E3 seem to go to the same "ground".
And no precision is needed on amplitude because R6 is a trim.
I'm wondering why not a 8:1 divider (say 33K in series with R6 5K) from R16. 500pFd in place of C8 and a 180pFd across R6 gives some low-pass action to reduce the even-order harmonics of the 160KHz signal.
(They may not have been too obsessed about even harmonics, because that power amp is crude and will throw some 2nd Harmonic, perhaps 1%?)
