rock soderstrom
Tour de France
Hey Sono, I don't have any answers, just questionsPretty bump....
This DC bias the MosFET to half operating voltage (B+) so that it can modulate equally in both directions.A question out of curiosity: R2 and R3 are a voltage divider right? Why lower by half the voltage to the Mosfet?
Indeed.This DC bias the MosFET to half operating voltage (B+) so that it can modulate equally in both directions.
Because common cathode tube outputs are 'mid-ish' impedance, and you want to follow the rule of voltage coupling which is try to maintain 10:1 input to output impedance. A 1M pot can tolerate a 100K output, however a 100K pot can only tolerate a 10K output. A 12AX7 with a 100K plate and 1K cathode has a roughly 35K output impedance, so you want at least 350K. 1M works fine too.Is there a specific reason why the Gain and Master pots are 1M?
A question regarding the master pot. Wouldn't it be better to position the potentiometer in front of the souce follower?Because common cathode tube outputs are 'mid-ish' impedance, and you want to follow the rule of voltage coupling which is try to maintain 10:1 input to output impedance. A 1M pot can tolerate a 100K output, however a 100K pot can only tolerate a 10K output. A 12AX7 with a 100K plate and 1K cathode has a roughly 35K output impedance, so you want at least 350K. 1M works fine too.
Something like this, perhaps also as Matador described. I wonder whether this has any significant advantages. The source follower acts as an impedance converter, like a transformer that guarantees constant output impedance. A good thing in itself. Are there any disadvantages?Do you mean like this?
[Any ideas, comments, suggestions before I melt some solder?] -- Go ahead and "melt some solder" and then let us all know what happened, OK??? Meanwhile.....I'll stay put here in my underground bunker, just to be safe, while you do so!!! -- GOOD LUCK!!! -- (as hatch clicks shut).....Any ideas, comments, suggestions before I melt some solder?
I know you use this preamp before an amp/power amp. I would be very interested to know how your amp behaves with the source follower in a standard 10k line input of an audio interface?Thanks for your reply
The idea is to be able to use it in front of an amp with good sound (before a power amp it already sounds great).
On that same thread I quoted before, there's this comment about the huge output this thing has :
Too much, too little gain and most importantly, how does it sound?
Well the idea is to be able to use it before an amp, before a power amp and directly into a mixer or a souncard. I recorded some short clips for you to have an idea how it sounds.
I agree with you, the preamp sounds like I expected it to - like a Fender amp. Very good, I am convinced of the solution. All in all, a very flexible and easy to set up instrument preamp. The unit will probably also harmonize very well with a Rhodes, Vox organs and similar keyboard instruments.To me it sounds REALLY good as a basic clean amp to which you can add other pedals and avoid carrying an amp, and still enjoy real tube sound and dynamics.
Maybe you can optimize it a little? Surely you have already tried a different tube?The only thing I notice is a TINY bit of hiss that increases as soon as you go into high gain. I don't know if it would be possible to eliminate that?
How do you generate B+? What does your power supply look like? Any "switcher" involved or classic tube transformer (or back to back transformers) plus CRCRC filtering?
I'll try to post that later todayEdit: can you please measure the total current is flowing on the B+ rail? Is it still under 15mA?
How do the clipping diodes in this circuit sound? Have you tried them yet?![]()
Is that with or without MosFET? A source follower normally needs more current...Ok, so I measured current between F1 and the junction R17-R10 and I get 0.850mA......but I'm not sure that's what you meant by TOTAL current flowing on the B+ rail, right?
This is the complete schematic of the preamp. Basically, it's a Fender AB763 without the Bright Switch, with added clipping diodes, split plate resistor and 6NxPs adaptor switch.
Thanks!I'll try to post that later today![]()
Perhaps these are artifacts of the NE555 PSU. I was never satisfied with this type of PSU. Maybe it's just me, but there are better solutions, even for pedals.I have tried 3 different tubes and they all hiss.
