M maye4 Active member Joined Mar 9, 2013 Messages 43 May 4, 2013 #1 I've already pulled the pcb out,But I don't know how to disengage the Capsule from the body. Does one have to do some trick inside the body? Thank you very much.
cyrano Well-known member Joined Sep 6, 2010 Messages 3,224 Location Europe Oct 21, 2013 #2 The top holding the electret capsule is glued on. And it requires a lot of force or heat to remove it. That's OK if the capsule is already defective. It will ruin it if not.
