grid_stopper
- Joined
- Mar 2, 2016
- Messages
- 204
I have a friend with a pair of yamaha pm1000 channel strips he had racked up. the output section is the standard feed taken from c37 and connected to a jensen je-123 output transformer, configured as 1:1. They are in the same enclosure, and when the strips are used one channel at a time, their is no noise, however when used as a pair one channel develops a nasty buzz, this buzz does not change with a cable change/swap, it stays on the same channel. flipping the phase at the channel strips input does nothing. to fix it, however flipping the phase down stream of his preamp, say on his interface does remove the noise. to me, this clearly indicates that the issue is somewhere in the output, but im wondering how this combination of things is possible.... would anyone care to speculate as to what might be going on there?
